Results 1 to 12 of 12
Thread: Drilling PCBs
    Jan 2010
    India
    Drilling PCBs
    I have seen many PCB drilling machines like below image.
    They have a metal base on which we mount PCBs for drilling.
    My question is what happens when the Z axis which is bringing the drill bit to PCB for drilling and the drill bit touch the metal plate below PCB. Will it not blunt or cut the drill bit? How they avoid the drill bit being touch to metal work plate?
    The video of the machine in action is here, but i cannot get clarification to my doubt by watching it or any other similar machines drilling PCBs.
    http://www.youtube.com/v/WF8DPSS9JnE
    Registered doorknob's Avatar
    Jan 2010
    This is just a guess, but I think that some people mount the PCB in a "window frame fixture" instead of placing the back of the PCB directly against the table.
    Think of mounting the PCB like you would mount the glass in a window frame. If you place a window frame on a flat surface such as a table, there will be a gap between the window glass and the table surface, while the frame itself sits directly on the table.
    Dec 2004
    Memphis, TN
    I mount my pcb's to a plastic/expanded foam spoilboard that I have leveled with the spindle.
    Jan 2010
    India
    Any picture or video would be good,
    Do you drill one PCB at a time or many PCBs?
    drk
    drk is offline
    Oct 2004
    india
    All PCB manufacturers use entry and backup materials when drilling copperclad laminates.
    The drill is never supposed to hit the metal bed and thus it is recommended u place a 2-3mm thickness bakelite sheet on the machine bed. Adjust your Z travel so that you get complete through holes drilled edge to edge of the pcb and that the drill dosent touch the machine bed.
    drk
    drk is offline
    Oct 2004
    india
    Sorry didnt read the second part to your question.
    You can drill and route a stack of upto 4, 1.6mm thickness pcs only if ur spindle is very good and powerful and your machine is tightly built. For hobbyist work, one at a time is good.
    Jan 2011
    Video of "drilling" PCB
    voodooengineering.com has a pretty good video of drilling PCBs. They don't have their etching video up yet though.
    He uses a vacuum table with the PCB and only drills half way through the material. Then he flips the board over and drills the other side.
    Oct 2005
    No offense intended, but that's just nuts! It more than doubles the drilling time and wear and tear on the machine and has a significant chance of misalignment.
    Commercial PCB houses use a cardboard-like disposable board under the PCB, then drill right through the PCB. Often they stack 2 or 3 PCBs when drilling.
    May 2006
    I use vacuum to hold PCBs while milling and drilling. And I drill through.
    The holes are tiny and amount to only a minuscule amount of the total board area.
    The vacuum easily copes with that. Drill after milling.
    Greg
    Oct 2005
    Do you have a photo of your machine Greolt?
    I've been thinking of building a small dedicated PCB router/driller.
    Registered Chris D's Avatar
    Apr 2005
    Drilling through the fiberglass PCB material is MUCH more damaging to the carbide drill bits than drilling into aluminum or even steel. However, that is not the best way to do it. Sooner or later your machine table will look like swiss cheese.
    Rather, as others have stated, you would use a backing material under your PCB that you drill into to - often referred to as a "Spoil". This can be any economical material such as wood or plastic.
    Chris
    Oct 2009
    China
    Quote Originally Posted by sunrom View Post
    Hello,Sunrom,
    Very glad to see your message and our pcb router's picture in here.
    For our JCUT-3030 pcb cnc router,it is the professional machine for drilling and milling pcb sheet,now i attached some sample pictures for your reference.
    Sunrom,can you tell me your detailed demands with the pcb cnc router?You can check the pictures to check whether it is the right one you want to get.
    Any question,please feel free to contact with me.My email/msn is jcutcnc@live.cn ,gmail is jcutdoris@gmail.com ,skype is lasercncmachine,yahoo is jcutdoris@yahoo.com .Waiting for your reply.Nice day!
    Best regards
    Sincerely,Doris
    Attached Thumbnails Attached Thumbnails Drilling PCBs-11.jpg   Drilling PCBs-22.jpg   Drilling PCBs-33.jpg
    1. New Machine Build- Low Cost Desktop CNC for Drilling PCBs
      By Robotics Guy in forum DIY CNC Router Table Machines
      Last Post: 08-20-2010, 02:32 PM
    2. Depaneling PCBs
      By ghassall in forum PCB milling
      Last Post: 08-09-2010, 05:52 AM
    3. Blank PCBs
      By Drools in forum PCB milling
      Last Post: 08-13-2009, 12:48 AM
    4. Small CNC machine for drilling PCBs
      Last Post: 06-20-2009, 01:37 PM
    5. Any got CNC for PCBs in San Francisco Bay Area?
      By jpm000001 in forum PCB milling
      Last Post: 08-16-2008, 10:21 AM
