Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: LPKF protoMat 91s help/users
    Oct 2010
    Belgium
    Hi all
    I have an LPKF protomat 91s second hand which is not working properly
    I can get the machine working with boardmaster 3.0 but still getting buffer
    overrun errors.
    It has nothing to do with boardmaster or with the commport settings
    (fifo is disabled,hardware handshaking is on)
    I tried on the same PC another promat91s which is working fine (without buffer overruns) which I dont have available anymore
    After getting in contact with lpkf i got several DB25 to DB9 cable layouts
    still searching for the correct layout.
    maybe there might be a difference in the 91s versions
    I replaced the RS232 linedriver max235 by i new one
    because the hardware handshaking part might have been defective,but no result
    As i saw that they used optocouplers CNY74-4 after the max235
    and I red in a documentation that the ground is isolated, i will try to
    replace those and see what happens
    (CNY74-4's are ordered)
    I would like to get in contact with other LPKF 91S users to share findings
    and eventual help me to solve this problem
    I hope this community will/can help me
    Looking forward
    May 2009
    I too have an LPKF 91s and I'm trying to get it to work. I read through your post and unfortunately I don't have a solution for your buffer overrun problem. I do however have the pinout for the DB9 to DB25 connector (should be attached to this post). I got this from LPKF's usa branch. Hope it helps.
    I also had a question that I was hoping you could answer. I'm unable to get my machine to talk to my computer over the com port. I start up boardmaster (im using 5.0 by the way) and it tells me to turn on the machine, which i do, but then it just keeps telling me to turn on the machine. I've scoped the com lines coming out of the computer and it looks as though the computer is trying to talk with the machine, but the machine is not responding. When I turn on the machine, it zero's itself in the x and y direction and then moves to the tool change position. From this I know that at least the machines motor driver boards are working. I've checked the com port settings on the computer (8N1, 9600 baud rate, etc..) and they all match what LPKF says to use.
    Any thoughts?
    thanks,
    - Will
    Attached Thumbnails Attached Thumbnails LPKF protoMat 91s help/users-25_9_null_cable.pdf
    Oct 2010
    Belgium
    Hi Will
    I got in contact with LPKF and found several Serial cable layouts, only 1 is working
    I build all the others without succes.
    Meanwhile I have a sencond 91S from a friend to compare which I will try in the upcomming weeks
    I already replace the RS232 driver IC without succes
    I now going to try the optocouplers CNY-14-4 and compare with the other
    DB25 LPKF DB25 Serial DB9
    1 ------------------------------ 1
    2 ------------------------------ 3 -------------------------------- 2
    3 ------------------------------ 2 -------------------------------- 3
    4 ------------------------------ 5 -------------------------------- 8
    5 ------------------------------ 4 -------------------------------- 7
    6
    7 ------------------------------- 7 ---------------------------------5
    8 ------------------------------- 20 ------------------------------- 4
    9
    10
    11
    12
    13
    14
    15 -----
    16 [ ( jumper between 15 and 17 )
    17 -----
    18
    19
    20 ------------------------------ 8 ------------------------------- 1
    21
    22
    23
    24 ------------------------------ 24
    25
    Quote Originally Posted by grossmanator View Post
    Any thoughts?
    thanks,
    - Will
    May 2009
    Thanks for your DB9-DB25 connector layout. I'm a little confused though. Why do you have three columns in your layout. Shouldn't there only be two (from the computer DB9 to the machine DB25)? Also, why did you try multiple connector designs? Isn't there a specified way of connecting the machine to a computer com port? When you tried other designs, did you try my layout that I posted? Just trying to figure out if my cable could be the problem. After looking at your cable design, I see that it is mostly the same as mine, but that there are a few small differences. This could be the problem.
    Oct 2010
    Belgium
    Hi
    Wel it was an original DB25 (lpkf)-DB25 (pc) with adapter to DB9 (pc)
    I measured also the DB25 to DB25
    in your case ommit the second collum and make the cable
    DB25 LPKF to DB9
    I noticed that there are hardware differences in the cables as i build
    2 cables suggested by LPKF without succes
    This one which is originally from a friend is working on mine and his LPKF
    exept that I have buffer overflow's but I think it is an hardware handshacke issue which i'm trying to solve
    Are you familiar with Circuitcam ?
    I might have some questions in the future
    May 2009
    When you tried using your friends LPKF, did you use your cable to connect to the machine? If you didn't, its possible that your cable is not entirely correct. I believe some of the pins in the cable tell each side whether the other side is ready to receive data/transmit data. Maybe you are missing a connection or two in the cable and this is the cause of your buffer overruns.
    May 2009
    I'm not familiar with circuit cam. I'm just starting to use this machine and I don't want to spend time learning circuit cam before I get the machine up and running. Also, I was just thinking: I'm using boardmaster 5.0 and you said you are using boardmaster 3.0. I wonder if this could be part of the problem. Why are you using 3.0 and not 5.0? What version is your friend (who has the other LPKF) using?
    thanks
    Dec 2004
    Memphis, TN
    He said the first column is DB25
    second is LPKF DB25
    and last is Serial DB9
    Oct 2010
    Belgium
    Thumbs up
    Boardmaster version has no influence, I use 3.00 as this is the one we bought
    Make this cable and probably it will work
    DB25 LPKF Serial DB9
    12 -------------------------------------------------------------- 2
    3 -------------------------------------------------------------- 3
    4 -------------------------------------------------------------- 8
    5 -------------------------------------------------------------- 7
    6
    7 ----------------------------------------------------------------5
    8 ------------------------------- ------------------------------- 4
    9
    10
    11
    12
    13
    14
    15 -----
    17 -----
    18
    19
    20 ------------------------------------------------------------ 1
    21
    22
    23
    24
    25
    May 2009
    Great, I will go make the cable (hopefully today). I'll post back when I know if it works or not.
    May 2009
    So I made the cable, but unfortunately it did not solve my problem. Still getting the same symptoms of the computer not seeing the machine over the com port.
    May 2009
    So I've looked through the connection documents and I have called lpkfusa a couple times and followed all the instructions exactly to no avail. I cannot for the life of me get my computer to connect to the machine. I have tried a different computer, I have tried several cables and I have opened up the machine to make sure no fuses are blown. I have even traced one of the pins on the db 25 connector into the machine through the maxim235 RS232 to TTL chip and then through the opto coupler and then the HC14 and it all seems to work just fine. The signal is getting through. I'm at a loss for what I should do next. I've tried using boardmaster 4.0 but that doesn't work either. Anyone out there have any ideas? thanks,
    - Will
  • Page 1 of 2 12 LastLast
    1. LPKF Stencil Laser G 6080 price?
      By johnfoilski in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 01-26-2011, 12:20 PM
    2. LPKF 91 Building new controller
      By swither in forum PCB milling
      Last Post: 10-29-2010, 03:50 AM
    3. LPKF rivets for via's etc
      By charliex in forum PCB milling
      Last Post: 01-10-2010, 04:27 PM
    4. Bungard or LPKF CNC milling machine
      By dakicha in forum PCB milling
      Last Post: 08-03-2009, 06:12 PM
    5. LPKF Typ 101 HI-P information
      By RikkieV in forum General Electronics Discussion
      Last Post: 10-07-2007, 01:04 PM
