Here are a couple of pictures:
(If this is in the wrong section just say so and I'll delete/move it)
I have a 60.000RPM GMN spindle with pneumatic ATC from a PCB drill that I realized I will never use so I wonder if anyone here are interested buying or trading something for it?
The spindle needs water for cooling, oil/air lubrication for the bearing and air pressure to operate the ATC/tool clamping.
These are the specification for it:
GMN TSS 62 - 60000
0,7kW S 6-60%
60000 1/min
165V 3,8A 1000Hz
I have a Danfoss 3 phase 230V 1000Hz inverter for it too.
I do not have the manual but I found one for a newer model that is pretty similar:
Manual
It weighs about 7kgs and is located in Sweden.
I may be interested in trades for linear motors, ballscrews/linear slides, Berger-Lahr 320Volt steppers, Granite Devices servo drivers, Sanyo-Denki Servo motors among other stuff.
You would probably have better results posting this in the classifieds.
