Page 1 of 4 1234 LastLast
Results 1 to 12 of 42
Thread: Line Grinder PCB Isolation Milling Software
    Jul 2009
    aaa
    Hello All
    I have just finished the first beta of some PCB isolation milling software which converts Gerber and Excellon files into GCode suitable for the isolation milling of circuit boards. The software is called Line Grinder. If anybody would like to try it out I would be happy to have feedback, bug reports etc.
    Line Grinder works on Windows systems, and is both free and open source.
    Of Itself So - Line Grinder, Gerber to GCode Isolation Milling
    Registered Drools's Avatar
    Feb 2009
    this looks interesting. I will give it a try. I was able to get the gerber files for Mardus-Kreutz open source driver. Thanks I will let you know.
    Jul 2009
    aaa
    Just a note to say Version 01.00 of Line Grinder is now out. Major changes
    - Added support for more Gerber code types
    - The user is now prompted to create a File Manager if one does not exist.
    - The requirement for defined reference pin pads on the PCB is now optional. If you were getting "No reference pins could be found on the PCB" messages with the last version you now have the option to open the Gerber File anyways.
    If your Gerber File will not open - please let me know. There are lots of Gerber "standards" and I would like to support as much as I can.
    Feb 2009
    none of the files I have are gbr files, this is what I have.
    They are in Gerber RS-274X created by Altium 2010 software.
    “A typical set of RS-274X file extension names is:
    .GBL - Gerber Bottom Layer
    .GTL - Gerber Top Layer
    .GBS - Gerber Bottom Solder Resist
    .GTS - Gerber Top Solder Resist
    .GBO - Gerber Bottom Overlay
    .GTO - Gerber Top Overlay
    .GBP - Gerber Bottom Paste
    .GTP - Gerber Top Paste
    .GKO - Gerber Keep-Out Layer
    .GM1 - Gerber Mechanical 1
    .GM2 - Gerber Mechanical 2
    .GPT - Gerber Top Pad Master
    .GPB - Gerber Bottom Pad Master”
    There is more info on this page: Gerber File - Wikipedia, the free encyclopedia
    Best regards,
    Kreutz
    Oct 2006
    I'm giving it a try
    Nov 2010
    Poland
    Hello,
    this is my first post here, so 'hi' everybody.
    I've just started to give a try to LineGrinder and DesignSpark PCB.
    It took me some time to work out the 'mm/inch' settings between these two applications (IMHO it should be one-place-only setup for Line Grinder to set mm or inches).
    But after all solved, I've got stuck with "No Reference Pin pads" error:
    11/16/2010 14:06:39 LineGrinder.GerberFile: SetReferencePins: No Reference Pin pads were found in the Gerber file. The File Manager thinks they should have diameter: 0.9
    Have Reference Pin Pads been placed on the PCB schematic?
    11/16/2010 14:06:39 LineGrinder.frmMain1: OpenGerberFile Error in call to GetReferencePinList. Error message is>No Reference Pin pads were found in the Gerber file. The File Manager thinks they should have diameter: 0.9
    I cannot go any further. Double checked the settings (ReferencePinPadDiameter value and other places according to the docs) but still LG cannot find this pads...
    Am I missing something here?
    Jul 2009
    aaa
    Hi
    I take your point about the mm conversion - that could be awkward to do. As for the issue you reported, do you actually have any pads of diameter 9mm defined on the PCB?
    If you do, and the Line Grinder software is not finding them, I am happy to take a look to see what the bug is. Email me via the address on the Of Itself So website.
    Cheers
    Cynic
    Nov 2010
    Poland
    9 mm?
    I tought 0.9 stands for 0.9mm...
    Jul 2009
    aaa
    Sorry, typo, I meant 0.9mm
    Nov 2010
    Poland
    Hey, new LineGrinder is available.
    Check here for release 01.03 changelog:
    I'm not an author but a happy user of LineGrinder and DesignSpark PCB
    Feb 2009
    Thanks for the note, I have been testing it once in a while.
    I'll give the new version a try.
    Registered Need TECH Help!'s Avatar
    Dec 2007
    U.S.A.
    Hello all,
    I have just tried the latest lineGrinder and cant get it to Generate Gcode. Gerber opens fine, but when i press Generate Gcode, i get an error window, see below picture.
    Any ideas?
    Thanks,
    Troy
    Attached Thumbnails Attached Thumbnails Line Grinder PCB Isolation Milling Software-memory_error_window.jpg
  • Page 1 of 4 1234 LastLast
    1. New PCB isolation milling software (beta verison)
      By dubble in forum PCB milling
      Last Post: 08-23-2010, 07:49 PM
    2. Need isolation PCB software??????
      By Burnit0017 in forum PCB milling
      Last Post: 06-09-2010, 04:05 AM
    3. Need Help!- milling a straight line that follows a 3d path
      By chaz6966 in forum BobCad-Cam
      Last Post: 03-20-2009, 11:28 AM
    4. PCB Trace Isolation - Minimum Track and Isolation
      By ahoodlum in forum General Electronics Discussion
      Last Post: 09-26-2006, 12:02 AM
    5. Assembly line capable milling machine
      By MrRage in forum General Metal Working Machines
      Last Post: 09-13-2005, 08:21 PM
