I use 1" for my tool change position. Looking at the G-Code it's just a single line for each path. Looking at your results you have some combination of the following:
1. Severe run out at the spindle
2. Feed is too fast the bit isn't cutting it's tearing
3. Backlash the different thicknesses in your lines show the system is off in one direction. Multiple pass jobs would remove all of the copper.
4. The wrong etching bit. Copper is soft and tears, pulls, stretches.
So try these:
1. You said the runout is .002", that's half the width of your bit ... may want to double check that
2. Slow the feeds down to 10ipm or less to gauge any improvement
3. You need to do the square and circle test or use a DTI and check this in both axis. Have you cut anything else with this machine? Something is loose and it shows worse the smaller/finer you try to go.
4. You have an engraving bit meant for a different job. www.soigeneris.com has the Precise Bits without the high shipping or minimum order ... www.drewtronics.net has solid carbide V-bits that are very economical, but have a .001" tip and thus take more passes to get a wide isolation. I use them for tight SMD work which I haven't done in a while.
Also, I have run your gcode through an optimizer to shrink the amount of Z air moves.
-Jay
LinkBack URL
About LinkBacks
