OK, so when I set a DOC at .008" the copper burrs like a guy from the Tropic of Cancer when he is in the Arctic. WTF. See picture #1.
My specs...
Router - 20K, 5 mils of runout
Feed - 15 IPM
Bits - V carve carbide, 60 or 20 degrees -
examples on eBay
Material - FR4 .05oz
Now when I do a DOC of .020" no burrs form and the results are fantastic. Picture #2, 5, 6, 7
However, I need to mill a board with thin and tight traces. Picture #3, 4
The copper clad is bolted down to a piece of MDF from there I can raise and lower the corners until the clad is flat to about .003ish. Sometimes I can see a bow (a lift) in the clad, but that does not effect the results seemingly.
The only thing I can think of is ditching the china bits and going with a drewtronics bit. IDK, Do you guys have and advice for about how to get those darn little burrs from forming so I can use a shallow DOC of .008"ish.
-Str
