Cheap & simple height-probing - Page 9
Page 9 of 9 FirstFirst ... 6789
Results 161 to 169 of 169
Thread: Cheap & simple height-probing
  1. #161
    Aug 2012
    Germany
    That sounds great.
    I'll have to check out CamBam.
    Gesendet von meinem INO_ONE_PLUS mit Tapatalk
  2. #162
    Feb 2009
    Bulgaria
    If you try CamBam and need assistance you can find me under the same nickname in their forum
  3. #163
    Aug 2012
    Germany
    Sorry, I didn't have time yet to add your patch.
    Christmas is coming awfully close.
    Gesendet von meinem Galaxy Nexus mit Tapatalk
  4. #164
    Aug 2011
    españa
    Quote Originally Posted by MarcusWolschon View Post
    I wrote it for pcb2gcode.
    I don’t know any real CAM programs that can do PCBs.
    What program created the g2 and g3 codes?
    Hello MarcusWolschonk, i have testing your program Pcbzcorret with pcbgcode 3.6.0.4 & eagle 6.2, i like so much, but i would like to change setting for default, by example:
    I like this:
    (Things you can change: )
    #1=2 (Safe height) => before #1=50
    #2=2 (Travel height) => before #2=4
    #3=0 (Z offset)
    #4=-10 (Probe depth)
    #5=100 (Probe plunge feedrate) => before #5=400
    (Things you should not change: )
    G21 (mm)
    G90 (Abs coords)
    M05 (Stop Motor)
    G00 Z[#1] (Safe height)
    G00 X0 Y0 (.. on the ranch)
    I could see in the two tests I have done, that the area where you have the reference pcb, would be the first step, you have a problem, since in that area not finish removing the copper engraver bit.
    Do you working in some new version the pcbzcorret?
    Regards
  5. #165
    Aug 2012
    Germany
    Quote Originally Posted by plutonn View Post
    Regards
    Could you explain please?
    I'm not doing much with PCBs myself at the moment so I'm only applying patches from other people.
  6. #166
    Aug 2011
    españa
    View picture.
    Attached Thumbnails Attached Thumbnails Cheap & simple height-probing-pcbzcorret-jpg
  7. #167
    Aug 2012
    Germany
    Did your original g-code include some ramping instead of plunging?
  8. #168
    Aug 2011
    españa
    I´m sorry, I didn´t save, i will should to do it again.
  9. #169
    Aug 2012
    Germany
    A new version has been created with the patch against excessive decimal places applied.
