If you try CamBam and need assistance you can find me under the same nickname in their forum
That sounds great.
I'll have to check out CamBam.
Gesendet von meinem INO_ONE_PLUS mit Tapatalk
Sorry, I didn't have time yet to add your patch.
Christmas is coming awfully close.
Gesendet von meinem Galaxy Nexus mit Tapatalk
Hello MarcusWolschonk, i have testing your program Pcbzcorret with pcbgcode 3.6.0.4 & eagle 6.2, i like so much, but i would like to change setting for default, by example:
I like this:
(Things you can change: )
#1=2 (Safe height) => before #1=50
#2=2 (Travel height) => before #2=4
#3=0 (Z offset)
#4=-10 (Probe depth)
#5=100 (Probe plunge feedrate) => before #5=400
(Things you should not change: )
G21 (mm)
G90 (Abs coords)
M05 (Stop Motor)
G00 Z[#1] (Safe height)
G00 X0 Y0 (.. on the ranch)
I could see in the two tests I have done, that the area where you have the reference pcb, would be the first step, you have a problem, since in that area not finish removing the copper engraver bit.
Do you working in some new version the pcbzcorret?
Regards
Did your original g-code include some ramping instead of plunging?
A new version has been created with the patch against excessive decimal places applied.
