Need Help! Hello Gurus
Results 1 to 2 of 2
Thread: Hello Gurus
    Dec 2016
    Default Hello Gurus
    Hi all you gurus,
    Frank from Australia, retired , sort of... I own/run a Caravan Park, which keeps me busy enough, but I want to get my Chinese 3020, which I had for the last 8 months, sorted out.
    I only want to use it for making circuit boards.
    Unfortunately, when I first got the 3020, I was busy as a City Councillor and could not really spare much time. This situation has changed, since I did not get re-elected :-( bummer.
    Never mind.
    If some good person would would have a circuit board file, that I can use to train myself using this 3020.
    I got Mach3 loaded and have some G-Code,stuff, but no printed circuit board G-Code. I realise that I have to make my own, I think using "Eagle", but first of all,
    I want to make sure that my machine works OK and I still have a lot to learn with Mach3 and G-Code.
    You all have a great 2017, you hear :-)
    Cheers
    CrankyFranky
    foreveryoung's Avatar
    Dec 2015
    Default Re: Hello Gurus
    Attached is an easy to mill G-Code (all tracks are 60mils). Please note that it has a drilling section (marking drill holes) at the begining,
    Attached Files Attached Files
Hello Gurus
Hello Gurus
