This and is much simpler and cheaper:
DIY Toner Transfer Paper & Techniques for making PCB,s Photo Gallery by Rolf at pbase.com
I am a complete newbie, I want to make a CNC for PCB making purposes, can I use these electronics
1. 2.6kg.cm Nema 17 stepper motor (CNC NEMA 17 Stepper Motor 5V 1 2A 2 Phase 4 Wire 2 6kg cm 1 8 Degree 3D Printer | eBay)
2. Polulu driver (1pcs A4988 Stepper Driver Module Polulu Compatible for RepRap Prusa Mendel M6 | eBay)
3. USB CNC Driver (4 Axis USB CNC Controller Cncusb Usbcnc CNC USB Alternative Mach3 Usbcnc 2 1 GE | eBay)
I want to make something small like whiteAnt.
And one extra question, I have seen buildyourcnc.com to use Belt and Pulley instead of Screw and Nut in many CNC machines, is that advantageous and reduce backlash error?
I am a computer science engineer and have a little less knowledge in mechanics so please consider if any silly questions are made.
-Thanks
- Rabbit RL_6040 Laser engraving/cutting machine Rabbit RL_6040 Laser engraving/cuttin
- Engraving is engraving a double line
- Newbie- Chinese Laser Cutting and Engraving Machine TS-6040 60w - Engraving problem
- PHCAD setting cut after engraving deeper engraving
- Distinction between laser engraving between special LGP engraving machine when produ
I would be most interested to know if you or anybody else could make the CNC driver (4 Axis USB CNC Controller Cncusb Usbcnc CNC USB Alternative Mach3 Usbcnc 2 1 GE | eBay) into a cheap cnc laser open architecture controller.
Maybe, I can push it for cutting small pieces of wood to make a bigger one. I have to start with a small one to make a big, right?
CO2 laser cost a lot, that I can't afford :-(
You can always start with something cheap like this:
DIY Laser Cutter
That looks interesting, how much can I cut by a 500mW laser? Can I cut a 3mm acrylic sheet? What factors depend on the wavelength of the laser diode?
How big can I make with two NEMA17? Please help
And the other answers?
1. how much can I cut by a 500mW laser?
2. Can I cut a 3mm acrylic sheet?
3. What factors depend on the wavelength of the laser diode?
