Results 1 to 7 of 7
Thread: Milling Depron Foam
    Nov 2005
    UK
    Milling Depron Foam
    Hi Guys,
    What is peoples opinion on the best milling cutter/burr for milling depron foam?
    I have done a few cuts with a Diamond burr and results are ok. Just wondering if there is anything better out there.....
    Mike
    Attached Thumbnails Attached Thumbnails Milling Depron Foam-milled_depron.jpg
    Aug 2006
    I use a rotorzip .125 grout removal bit at 10k rpm. The machine is a phlatprinter designed for cutting sheet foam RC airplanes.
    Are you using the same machine? The tabbing looks familiar.
    Nov 2005
    UK
    I`m using a Step Four basic 1000 for my milling and general cnc routing. What do you mean by tabbing?
    I`m not sure what rotorzip is, is that like dremel? Have you got a link to the cutter so I can see what the profile is?
    I quite like having a radius or dome cutter as it avoids getting a sharp edge on the milling.
    Aug 2006
    I use the term tabbing to refer to the tabs needs to retain a cut part within its medium during the cutting process.
    A rotorzip is a fancy Dremal. One of many styles
    The bit is like this but has more bit cutting lenth and was a lot cheaper at my local shop.
    The bit is basically a barrel with sharp bumps all over. I've cut up to 40 ipm (my machine max) and never had any melting issues. I did with all fluted bits I tried.
    Nov 2005
    UK
    arh ok...the tabs I put in on my cad software. The step four cnc software does not include a feature to add tabs so I put them in manually.
    The cutter you are using, is that more for completely cutting parts out? I`m experimenting with pocketing areas to leave about 1mm wall thickness at the moment.
    Aug 2006
    I don't seem to have any trouble with pocketing. The phlatprinter web site has a few good pics of what can be done, just search the gallery. For a machine that can be assembled with most of its parts from a local hardware store it works surprising well.
    http://www.phlatboyz.com/
    Registered kram242's Avatar
    Mar 2005
    Phlatrpinter
    Rc3Dpilot, thanks for the compliments on the Phlatprinter. We're glad you are happy with it.
    Also wanted to put a thank you out there to everyone here at cnczone. This is where we learned everything we needed to know about CNC. We couldn't have done it without everyone's help.
    We want to let everyone know we have 5 Phlat-Premium Kits ready for shipment in 1-2 business days. After these 5 Phlat-Premium Kits are gone, we will not be making any more until the new year.
    We have 5 Phlat-Bonez Kits ready for shipment in 1-2 business days. After these 5 Phlat-Bonez Kits are gone, shipment may be delayed for a few days to give the manufacturer time to make more.
    Thank you and have a Merry Christmas!
    Mark and Trish Carew
    Phlatboyz.com
    1. Cutting Thin Foam (Depron) please help!
      By adbradley in forum CNC Wire Foam Cutter Machines
      Last Post: 12-18-2008, 04:02 AM
    2. Milling Foam
      By apeman88 in forum Tormach Personal CNC Mill
      Last Post: 07-07-2008, 04:23 AM
    3. Need Help!- Milling soft cushioning foam?
      By corpseguy in forum CNC Wire Foam Cutter Machines
      Last Post: 02-23-2008, 05:06 PM
    4. Foam & Wood milling machine
      By perolalars in forum DIY CNC Router Table Machines
      Last Post: 04-11-2007, 12:42 PM
    5. CNC Router for 1/4" Depron foam
      By CDignition in forum DIY CNC Router Table Machines
      Last Post: 12-30-2004, 07:36 AM
