Check this section out- http://cnczone.com/forums/forumdispl...s=&forumid=164
Can anyone recommend a relatively small and "cheap" cnc mill that will allow me to do small(say 1 foot x 1 foot max) aluminum hop up parts for R/C models?Need some insight and plans on such a mill. How much would something like this end up costing totally? Are CNC's that cut aluminum hard to come up with?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
You may also want to look at the Drill/Mill CNC conversion for doing metal cutting. I converted my Enco and it does nice work on Aluminum and Steel.
Jeff Davis (HomeCNC)
http://www.homecnc.info
I have built a Zoltar http://www.rcmodels.net/cnc/
and I must say it is just very nice I have done some jobs for a friend 1 mm brass it worked I haven't tried aluminium but I think it's no broblem.
cost about USD600 and USD125 for the PCNC software.
SignIT
Originally Posted by debutis
Signit: There is one thing that would improve that machine a lot. That is to add some ribs to the vertical parts of the gantry. Using just sheet metal, it will wobble sideways under cutting loads. Just adding some aluminum square tubing or profiles vertically up these sides will improve a lot at almost no cost.
ESjaavik: If you look closely at the pics of the machine you can see there is one rib just beside the handwheel for y screw
Bent
OK. I didn't notice that. But a bit more would not hurt.Originally Posted by Bent
So, another Scandinavian here. Shall we hijack this place?![]()
