Results 1 to 3 of 3
Thread: glider bigbrother dxf and gcods
    Registered dpot's Avatar
    May 2005
    FRANCE
    Hear is a glider caled bigBrother in dxf and is set out on a
    1200 x 300 x 3mm Sheet of light ply, for the booms I used the top of fishing rods but 10mm carbon wood be beter,I made the fuz and wing first with all the raido moter and batrey installed and then fited the boom with the v taile to get the right center of ballence
    sorry for that i forgot to explode the dwg before exporting and pergeeing
    have a go at this there is sum gc for kcam with 0 offset with a 3mm router bit will cut on the line
    Attached Files Attached Files
    Registered planekrazie's Avatar
    Apr 2006
    Love It.
    You wouldnt have to have the nc Files would you. I for the life of me can not get the 1st file with the fuse to show up with lazycam under mach3
    Steve <------- Still a nubie
    Site Owner CNCadmin's Avatar
    Mar 2003
    Nice, great plane for some laser cutting.
    Thank You,
    Paul G
    Site Owner-Webmaster-
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
