Build Thread Aftershock ... rc glider - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: Aftershock ... rc glider
  1. #21
    Registered Arbo's Avatar
    Jan 2008
    Default Re: Aftershock ... rc glider
    Well I prepped up the tail plug with dam's around it. Mixed up epoxy and aluminum powder for a gel coat. Loaded it up. Once that get's a little hard, will add glass and such as backing to strengthen it.
    Attached Thumbnails Attached Thumbnails Aftershock ... rc glider-f0cdddd3-8a9c-4d8f-a133-87d59ff56361-jpg   Aftershock ... rc glider-634fea0a-a69e-445c-9f9e-fd888ac2005e-jpg
    Wood neophyte.
  2. #22
    Member Jerseydog's Avatar
    Dec 2012
    Usa
    I can't wait to see the end result. This is the main reason I started building my CNC. But it's smaller then your's so I can't build the wing that length. Keep up good work arbo.
    Sent from my SM-N900T using Tapatalk
  3. #23
    Jan 2008
    Yeah, this is the reason I built my CNC, and after all these years, I am finally using it for that. lol. But you can do two piece wings, so no problem.
    Wood neophyte.
  4. #24
    Jan 2008
    Popped it open just a bit ago. This is it just opened. Loads of clay to clean up and edges to sand down. Overall not bad for a first go at it.
    For the next one, which will be the other side of the mold, think I am gonna try to pour paraffin wax in the trough instead of clay, less cleanup I think. Also do a little better with the clay around the edges of the damn.
    Attached Thumbnails Attached Thumbnails Aftershock ... rc glider-58449cd7-d609-48d6-a1ce-53c5d3c3b4d0-jpg
    Wood neophyte.
  5. #25
    Jan 2008
    Bottom wing mold cut.
    Attached Thumbnails Attached Thumbnails Aftershock ... rc glider-b6c601f2-25d2-4563-b0af-82cfec7f2fa7-jpg
    Wood neophyte.
  6. #26
    Jan 2008
    After being away from this for a bit due to vacation and then work... am back at it. Decided to cut molds for tail surfaces out of corian, as there was no point doing plugs then molds.. let's just skip a step.
    Have horizontal parts done, polished, waxed, painted.. when that cures will lay up the halves.
    Attached Thumbnails Attached Thumbnails Aftershock ... rc glider-273e54f0-8491-4cb8-a241-c8fcf327ebe2-jpg   Aftershock ... rc glider-184e2908-b50a-4786-aeaf-a58b2db7d266-jpg
    Wood neophyte.
  7. #27
    Dec 2012
    Usa
    Woo-hoo I was waiting.
  8. #28
    Dec 2004
    Looking good.
    Mike
  9. #29
    Jan 2008
    First I had to cut out a template for the horizontal shape, for material. I should actually make another that has holes where the dimples are so I don't have to do that by hand, or can at least mark them to cut. Also one for the balsa used because it does't go the full width of the part.
    Then I cut out light glass for the layer against the paint, so hopefully there is no print through. Then glass, carbon, balsa, and last layer of glass. Some kevlar for the hinge line.
    Wet it all out, placed in the mold's, working out bubbles and getting it lined up as best I could. Then two layers of peel ply (because the first test I could not get it off the part without popping the part out of the mold), and I don't have any perferated plastic.. need to order some. So hopefully this one will peel off better. Covered with paper towels, then into the bag.
    Attached Thumbnails Attached Thumbnails Aftershock ... rc glider-20160724_114111-jpg   Aftershock ... rc glider-20160724_120447-jpg   Aftershock ... rc glider-20160724_125419-jpg
    Wood neophyte.
  10. #30
    Jan 2008
    Well, pulled from the bag, you can see it with one layer of peel and paper towels pulled off. The second layer of peel came off ok, without popping the part out of the mold, but gonna get some perf plastic to use as well.
    The fluorescent paint used didn't work well, that's crossed off the list of possibilities. I think that was rustolium, will try krylon as well. The other sprays used work fine.
    Out of the mold and trimmed up a bit. This one will just be used to mount on the fuse mold with some thickened epoxy to get the saddle for it to the perfect shape.
    Attached Thumbnails Attached Thumbnails Aftershock ... rc glider-20160724_165353-jpg   Aftershock ... rc glider-20160724_195407-jpg   Aftershock ... rc glider-20160724_195915-jpg
    Wood neophyte.
