Results 1 to 4 of 4
Thread: System Variable Z Work Shift
    Jan 2009
    Question System Variable Z Work Shift
    Gentlemen,
    I have a Kia lathe with a Fanuc O-TD control on it and I need to know what the system variable for Z axis work shift (not G54 to G59 workpiece offset)
    but the work shift. Thank You
    Feb 2004
    somewhere out there
    Feb 2006
    india
    Actually #5203 is for Z-axis external offset on a milling machine. On a lathe, it is #5202.
    For work coordinate shift, the system variable is #2601 (for Z-axis). It shifts all the coordinate systems (G54 etc) by the specified amount, in the opposite direction. For example, if Z-display is 100, it would change to 110, if you specify #2601 = 10.
    Coordinate shift is not available on milling machines.
    Feb 2004
    somewhere out there
    oh yea... duh... sorry... memory ain't the greatest anymore
  1. work shift
    By teamus in forum Hardinge Lathes
    Last Post: 06-10-2009, 06:32 AM
  2. Replies: 2
    Last Post: 03-20-2009, 04:54 PM
  3. Shift option on Fanuc 6M system, very OLD controller
    By shape in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-13-2009, 03:59 PM
  4. Problem- c axis work shift
    By Atlas_Too in forum Fanuc
    Last Post: 10-13-2008, 01:14 PM
  5. Automatic work shift on lathe, is it possible?
    By DonutSlayer in forum G-Code Programing
    Last Post: 05-28-2007, 12:48 PM
