Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 11-09-2009, 11:28 PM
Ashish B's Avatar
Ashish B is on a distinguished road
Smile Excluding Negative sign in Parametric Programming
Hi all
Please have a look over the Following Example -
For Instance,
If 101 = 3.456
& 102 = -1.234
I commanded
#103 = #101 - #102
will turn into
#103 = 3.456 - ( -1.234 )
A mathematical equation states Minus + Minus Equal to Plus
So, it will be
#103 = 3.456 + 1.234
#103 = 4.69
But according to the Commanded Equation
#103 =3.456-1.234
#103 = 2.222...................(The Intended output which i wanted).
So what should be the programming Pattern to get the intended Output ??
Or
Is there any command which consideres the Negative Sign & will only consider the Value excluding the Sign.
Ash
Old 11-10-2009, 01:30 AM
dcoupar's Avatar
#103=#101-ABS[#102]
Old 11-13-2009, 11:42 PM
Ashish B's Avatar
Smile Hi
Thanks for that Magic Command.
Thanks a lot
Ash
Parametric Programming Tuz Parametric Programing 7 02-09-2009 09:27 AM
New to Parametric Programming weaston G-Code Programing 4 02-27-2007 08:40 AM
Parametric Programming weaston General CAM Discussion 4 02-20-2007 08:25 AM
Parametric Programming widgitmaster BobCad-Cam 7 05-04-2006 02:04 PM
parametric programming Karl_T CamSoft Products 21 05-24-2005 03:58 PM
