| Parametric Programing (custom macro b, fadal macro, okuma user task) |
I have a Heian Router 180im-b Fanuc Controller I am trying to take a standard downshear bit and do an x,y,z, movement while also following a specified radius. Then follow it back up the same way it came down. I have been told by a few different people it can't be done. But it seems so simple?? I have come up with nothing but error messages though when trying myself. Help anyone?? |
| Not really sure about the control or machine put it sounds like you are trying something more complicated than you think. Especially if your control is erroring out. Sounds like you want to move from XYZ point A to XYZ point B, all the while generating a radius. If that is the case you either need to generate the path using CAD/CAM or author your own macro to calc the XYZ per any given step along the radius and interpolate to that point then calculate again. |
| If you want the radius to be in the XY plane and ramping up and down (straight line from the side) you need to have helical interpolation turned on. You just might. If you want your radius to be in a plane other than XY, XZ or YZ, then helical will still work, but you need to change panes (G17, G18 and G19) Any other planes, you need coordinate rotation (maybe it would work, never tried it) AND helical interpolation. Other than that, have someone write some code from their CAM system in pure linear that you could cut/paste in your program. |
| tHE BOLDED PART IS WHAT I AM WORKING ON... N10G0G17G20G40G49G80G90Z0 M211 M400 M401 T3M6 G08P1 N20G54M91S20000X[#500-3.0]Y3.155 N30G43H3Z.25 G42D19 G90G1Y2.155F150. N40G1G90Z-.3865X[#500/2]F243.75 X2.155F325. N50Y[#501-2.155] N60X[#500-2.155] N70Y2.155 N80X2.9175 N90G40G49G0G64Z0M95 M400 M402 T3M6 N100G55M91S20000X[#500-3.0]Y3.155 N110G43H35Z.25 G42D51 G90G1Y2.155F150. N120G1G90Z-.3865X[#500/2]F243.75 X2.155F325. N130Y[#501-2.155] N140X[#500-2.155] N150Y2.155 N160X2.5575 N170G40G49G0G64Z0M95 M400 M401 T4M6 G54M91S20000X[#500-3.0]Y3.155 N190G43H4Z.25 G42D20 G90G1Y2.155F150. N200G1G90Z-.125X[#500/2]F187.50 X2.155F250.G61 N210Y[#501-2.155] N220X[#500-2.155] N230Y2.155 [B]G91G2X.194Y.194R.219Z-.2615 G3X-.194Y-.194R.219Z.2615 N240G1X2.2331 Z1.0 G0G40X6.Y6. N250G0G49G64Z0M95 M12 M22 /G53Y0 N260G08P0 /M212 M99 |
| G17 G0X0Y0Z3. G1G91X1.F50. G2I-1.(THIS.SHOULD.RUN.FINE) G2Z-.1I-1.(THIS.WILL.ONLY.RUN.WITH.HELICAL) G1G90X0 |
| Thanks for your reply,what will this tell me when I run that code? What am I expecting it to do? I run can run a program like this: (Is this Helical?) N20G55M3S18000X3.75Y2.75 N30G43H24Z0.25 N40G1Z-0.4F100. N40G62G91G2J1.F200. G2J1.F400. G2J1.Z0.5F400.G61 G90X3.75Y3.125 G1Z-0.4F100. G91G62G2J0.625F200. G2J0.625F400. G2J0.625Z0.5 |
#10
I'm not a mill guy so I'm not sure what the G61 and G62 are doing but... if these lines... G2J0.625F400.(cut a circle using XY) G2J0.625Z0.5(cuts the same XY circle while moving in Z) then you have Helical and you "should" be able to do what you want. Provided that the Sarting point A and Ending point B are valid starting and ending points along the selected plane at the given radius. Good Luck! |
#11
| If I start at X 2.155 Y 2.155 Z-.125 and I want to go to X 2.349 Y 2.349 Z -.3865 while following the .219 radius will this work?? G91G2X.194Y.194J.194Z-.2615 G3X-.194Y-.194J-.194Z.2615 Where does the radius call out go? Sorry I am failry new to all this, and I have no cad software to work from. I learn as much as I can by writing them by hand. But I am running out of time to complete this project. Thanks for your help!! |
#12
| If you use I and J to specify the distance from start to center, you don't need a radius call out. I'm pretty sure your above example will not work (it will create a 3/4 moon shape). J.194 in the G02 block puts the center +.194 in Y from the start point. J-.194 in the G03 block puts the center -.194 in Y from the start point. I would replace the J.194's with R.219's. I back plotted it and it worked fine with R's. What alarm are you getting? |
| "Radius to end of arc differs from radius to start on Line #" | labuda | G-Code Programing | 8 | 11-15-2009 07:35 AM |
| Need Help!- Outside radius | Shibumi | G-Code Programing | 1 | 10-30-2008 11:27 AM |
| Problem- radius help | Scott Halstead | GibbsCAM | 0 | 06-12-2008 08:27 AM |
| big radius | Dembo | Mechanical Calculations/Engineering Design | 10 | 02-01-2008 12:01 PM |
| Zero Radius Arc | Xular | Mach Mill | 4 | 12-13-2006 10:10 PM |
