Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
  #13   Ban this user!
Old 07-09-2009, 11:37 AM
Tuz Tuz is offline
Tuz is on a distinguished road
Thanks I will try it.
The alarm I was getting was ARC out of tollerance
  #14   Ban this user!
Old 07-09-2009, 11:44 AM
ProProcess is on a distinguished road
that means that the starting, ending and center call outs do not "fit".
follow dcoupar's advice and remove the center callouts and replace with radius.
this will force the control to fit the commanded radius into the starting and ending points.
Good luck
  #15   Ban this user!
Old 09-03-2009, 04:54 PM
FZR1000 is on a distinguished road
hello
i created a macro program tot mill a given radius on a straiht line
in case you dont want to use a concave or convex mill
the sub progr. calculates the distance of each step in y and z
if it has to be a smooth surface you take a one degree step or
more for faster results
i start at the top of the workpiece and mill then from left to right
calculate a new y and z and go from right to left and so on
until i reach a rotation of 90 degrees
start is at Z0 and finish is at Z-5
it works without radius compensation!!
i am using a 20 mm mill with 0.8mm radius on the edge
and i work in mm not in inches, but that must be no problem
is this wat you have in mind ??
sorry for the bad writting
O0310(PARAM.RAD 5MM)
G1902B100D100H25I0J50K0
G0G91Z0M19
T17
M6
M03S1500
G00G90G54X-20Y-10
G0G90G43H17D17Z50
Z0
G01Y-10
G65 P9060 A1 B5 (a= degrees B=radius)
M09
G0G91G28Z0M5
G91G30X0Y0P3M9
G90M37
M12
M30
here folows the subprogram
O9060(SUB310)
#3=0+#1
N1
IF[#3 EQ #3]THEN#3=#3+#1
IF[#3 EQ 90]GOTO10
#25=#2*COS[#3]
#24=#2*SIN[#3]
#26=5-#24
#27=5-#25
G01X-20
Y#26
Z-#27
X125
IF[#3 EQ 90]GOTO10
#25=#2*COS[#3]
#24=#2*SIN[#3]
#26=5-#24
#27=5-#25
Y#26
Z-#27
G01X-20
GOTO1
N10
M99
greetings fzr1000
"Radius to end of arc differs from radius to start on Line #" labuda G-Code Programing 8 11-15-2009 06:35 AM
Need Help!- Outside radius Shibumi G-Code Programing 1 10-30-2008 10:27 AM
Problem- radius help Scott Halstead GibbsCAM 0 06-12-2008 07:27 AM
big radius Dembo Mechanical Calculations/Engineering Design 10 02-01-2008 11:01 AM
Zero Radius Arc Xular Mach Mill 4 12-13-2006 09:10 PM
