Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 05-08-2009, 07:01 PM
mocre is on a distinguished road
help in fanuc macro
hi boys,
I have old fanuc OT control. Where the rigid taping are not possible.
is that possibly this problem to solve with macro.
I have an idea but how I am not possible this forms in macro that
for example; I want 20mm deeply tap where going for a ride languages runs gradually to zero to depth, afterwards with M04 the other way around.
helps someone me? in advance thank .....
sorry for my bad English.
Old 05-13-2009, 07:53 AM
stevo1 is on a distinguished road
PM Sent.
Stevo
Old 05-13-2009, 08:26 AM
Brakeman Bob is on a distinguished road
Originally Posted by mocre View Post
hi boys,
The short answer is no because rigid tapping requires a spindle motor that has its encoder integrated with the axis controllers. in other words the spindle will rotate 1 revolution EXACTLY as the Z axis moves one pitch of the programmed thread. You coud try rigid tapping with a non-integrated spindle and you might be successful but I think you will break a few taps along the way.
However, if your control has in terms of "number of revolutions turned" then you might be able to do this thing in a macro if you can conrol very accurately the start and stop of the spindle and of the Z axis. You also will not be able to test it in single block as to be effective rigid tapping of one hole must be executed in one block by the control.
Old 05-14-2009, 06:16 PM
thank
thank for your response, indeed I am possible in a rule no going for a ride languages and dipped on z ash to regulate. I think that the problem is.
Tags
cnc lathe, fanuc, macro, programming
fanuc macro nutty Fanuc 6 12-22-2010 11:34 AM
Testing program for Macro (Fanuc Macro B) NickDP Fanuc 2 03-27-2009 04:15 PM
Fanuc Oi MC and macro B chrisryn Fanuc 2 05-20-2008 02:31 PM
Convert Fanuc Macro to Fadal Macro bfoster59 Fadal 1 11-09-2007 12:41 AM
Macro help FANUC 16 I mb Bluesman General CNC (Mill and Lathe) Control Software (NC) 4 02-07-2006 04:05 PM
