Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 03-02-2009, 12:17 PM
JMECKES is on a distinguished road
Changing signs using variables
We are using Custom Macro B extensively on a CNC lathe. When trying to change the sign of a variable from positive to negative, we seem to only be able to change it using a two line formula. In the example below, we are trying to change variable #527 to a negative value. I would like to do it on one line, but either MacroB doesn't follow all algebraic rules or my algebra just plain sucks (and that may very well be the case). The fact that we can't use parenthesis doesn't help either, since the control ignores it like any comment in the code.
#6=#527-.12
#6=-#6
I've tried things like #6=[-]#527-.12 and #6=[[#527*-1]-.12]
Any suggestions from the sharp folks on here?
Old 03-02-2009, 12:48 PM
beege's Avatar
beege is on a distinguished road
As far as I understand it, 1-33 are reserved for argument transfers from the G65 macro call line to the macro. I'd use either the common variables 100-199 (which reset to null on power off/on cycle) or 500-599 (which stay put when powered is cycled).
#100=-[#6]
of course, you could try #6=-[#6], but i wouldn't because I don't like using those variables as a matter of personal taste.
Old 03-02-2009, 04:20 PM
ChattaMan is on a distinguished road
Or maybe...
You could try...
#6=[#527*[-1]]-0.12
Old 03-02-2009, 07:09 PM
Kiwi is on a distinguished road
Or this
#6=[0-#527]-0.12
Old 03-03-2009, 08:40 AM
stevo1 is on a distinguished road
What number is #527 usually set to? Are you trying to get a negative value for the result of #527-.12? Where is #6 playing a factor into your calculation? There is a few ways to do this. If the value of #527 is normally greater than .12 you can reverse the calculation. Ex #527 is set to .7 #6=.12-#527=-.58
I guess you didn’t need all of that but anyway if you want #527 set to a negative value program #527=[-#527]. This works on all of my Fanuc’s. Or you can use as Beege has formatted #527=-[#527]
Beege,
FYI….you can use #1-#33 anytime that you want. You don’t have to use them exclusively as a passing of variables with the G65 command.
Stevo
Old 03-03-2009, 09:36 AM
perkulator is on a distinguished road
how i did it on an Okuma
VC10=VC10*-1 when using global variables.
Hope this helps you.
Old 03-03-2009, 09:42 AM
beege's Avatar
Originally Posted by stevo1 View Post
Beege,
Stevo
Yup, knew it; just don't as "a matter of personal taste". Thanks for the reaffirmation.
Old 03-03-2009, 09:54 AM
Perkulator,
Jmeckes never told us what control he was using. Now this could depend on what control he is using but none of my 15 series Fanucs support #527=[#527*-1] it is an improper format. I am assuming that he is using a Fanuc and this statement will not work. However I have seen this format in other threads so it must work on different controls.
Beege,
I am just opposite. I like to use the #1-#33 just for the fact they clear at reset or program end. No chance for opps forgot to set it to 5 in the second program when it was used as 1 before that. I also like the fact that if I want to go 2 subs deep I can use them again in the second program set to a different number and they return to the previous value when coming back to the 1st sub. As you know with macros there is dozens of ways to approach it. No 1 way is right or wrong.
Stevo
Old 03-03-2009, 04:43 PM
It's a 21i on a sub-spindle lathe. We are using it to control the depth of a drill at the end of a peck cycle. That's where the - comes in. The positive values used for the sub were no problem for the calculation. We ended up using Kiwi's formula, but both that one and Chattaman worked for what we needed. Thanks all!
Old 03-03-2009, 10:38 PM
psychomill is on a distinguished road
Why bother with the math? so to speak....
Just say...
-#527
But without knowing what the conditions are...
Are you trying to use #527 as a negative function?
-#527
or you just simply want to insert a negative value in #527?
#527=-#527
It's just a part..... cutter still goes round and round....
  #11   Ban this user!
Old 03-04-2009, 08:47 AM
The program is variable loaded so I was trying to simplify and reduce program size. By keeping the sign change on one line of code instead of two, we are able to greatly reduce the size of the program. This also helps when it comes to training employees who are new to parametric programming. We've found that loading a control with a series of "variable" programs and having the operators copy and merge these mini programs is much less time consuming than using CAM software, and definitely more efficient than writing line by line G code. For almost everything we do now, we just have to input numbers without writing the entire program.
  #12   Ban this user!
Old 03-04-2009, 09:49 AM
edit...
never mind... missed one of your posts....
Need Help!- Carving Signs Sam A BobCad-Cam 2 05-04-2008 10:01 PM
Painting wooden signs? abomb55076 WoodWorking 26 08-07-2007 11:39 PM
RFQ Billet superman signs clarq_kent Employment Opportunity 21 05-26-2007 12:40 PM
wood signs Pugster WoodWorking 1 07-08-2006 12:21 AM
Top Ten Signs wms CNCzone Club House 19 06-21-2003 08:04 PM
