| Parametric Programing (custom macro b, fadal macro, okuma user task) |
Can anyone help me, I need a macro to automate a pneumatic punch in my cnc program and I haven’t a clue where to start. What information is needed to write a macro for this application ? Are there any templates around that I can have a look at to get me pointed in the right direction? Any help will be much appreciated. Regards Colin |
| The controller software i am thinking of using is Mach 3 , but will be programing in Mastercam. The machine will only have an X axis and the punch will be set fixed at the right position along the y axis and will not need to move. The material will move along the x axis to the correct position, then i would like to activate the punch from the program. So basically the program will consist of G0 X axis moves to each hole position, then the macro to activate the punch at each hole position. I hope this makes it a bit clearer. Thanks again |
| I have never programmed Mach3 so this might not fit exact. Do you know if your control supports variables #1,#2, #100 ect.? There is a few different ways that you can go about this. From what you have said the only variable from job to job will be the distance to travel in the X from punch to punch? And I would assume the number of punches in a given job? What is your code for activating the punch? I would look at programming it like this as long as the control can support IF,THEN,WHILE statements. O0001(punch macro) #100=1.2---------------hole to hole X distance #101=50----------------number of holes to punch WHILE[#101GT0]DO1 G0G91X#100-----------INCREMENTAL this can be set up absolute if you want M123------------------code to activate the punch #101=#101-1 END1 M30 This will keep looping through moving the X1.2" at a time then punching. It will do this 50 times or what ever you set #101 equal to. Then it will end. Stevo |
| Punch?? or What?? | ShayArnett | General Metalwork Discussion | 8 | 03-19-2010 10:28 PM |
| Macro for turret toolchanger needed for boxford TCL | richmond | Mach Wizards, Macros, & Addons | 2 | 11-18-2008 08:47 AM |
| TOOL CHANGE MACRO NEEDED? | offroadxx | Fanuc | 3 | 01-08-2008 01:10 PM |
| Convert Fanuc Macro to Fadal Macro | bfoster59 | Fadal | 1 | 11-09-2007 12:41 AM |
