Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 10-06-2008, 11:11 AM
mikeyson is on a distinguished road
Fanuc 18T program/parameter question
Is there a parameter that will allow letters to be used in the program #? For example: O1234(A). We would like to have both O1234 and O1234(A) available in the directory, currently it will overwrite the existing O1234(A) program. The machine is a Daewoo Puma 230ms with a Fanuc 18T.
Old 10-06-2008, 12:51 PM
stevo1 is on a distinguished road
I think you can only use numbers. However check your book because I believe that on the 18 series control you can use more then a 4 numbers to define a program. For example if you have 3 different operations for program O1234 you can do O12341, O12342, O12343. I am not 100% but maybe up to 8 digits.
If you want to stop the programs from overwriting it is parameter 3201 bit 2. This will generate an alarm if a loading a program with the same program number is already in the control.
Stevo
Old 10-06-2008, 01:30 PM
I was afraid of that. I'm going to have to see if there is a parameter for the number of digits. Our machine will only accept 4 digits.
Fanuc OT parameter(s) erwin1958 Daewoo/Doosan 5 03-26-2009 11:36 PM
fanuc 15m program overwrite parameter jlong58 Fanuc 6 12-02-2008 12:16 PM
Fanuc O-M Parameter question caddyshack Fanuc 1 04-22-2008 09:00 AM
Fanuc 0T parameter Master_CNC General CNC (Mill and Lathe) Control Software (NC) 0 11-26-2007 02:15 PM
Set parameter from program....? REVCAM_Bob Fanuc 25 01-26-2007 09:11 PM
