Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
  #13
Old 09-03-2008, 10:22 AM
HuFlungDung's Avatar
Moderator
Originally Posted by g-codeguy View Post
HFD. 2 things. I couldn't find inverse time mentioned in the manual, and 18 second cycle time is way too long if it were using inverse time feed. So I guess this means the control is using degrees per minute???
Bringing me back to my original question. How do I figure feedrate? Would a call to Daewoo be appropriate? I've always had good luck tapping into the knowledge on forums.
BTW, G94 is a canned facing cycle. No G93 mentioned.
By all means, call Daewoo to get the low down if you can't find it in the manual.
By means of a few experimental movements with C axis only, and various feedrates, you should be able to determine if the feedrate is degrees/min. All you need is a stopwatch and program a 360° movement at F360. Should take exactly one minute to execute.
As for calculating the feedrate, it is always going to be a matter of calculating the distance along the circumference, divided by the time taken to do it.
Eg: (1500°/min) / 360 = 4.166 revolutions per minute
Circumference = .426 * Pi =1.338"
Distance = 1.338 * 4.166 = 5.575"/min
The 'feedrate' is only correct at the radius used for the circumference calculation. So if it does turn out to be degrees/min feedrate, then the actual equivalent linear feedrate is proportional to the radius of the part. The control has no idea what radius the tool is cutting at, so that is up to you to calculate and input accordingly.
  #14   Ban this user!
Old 09-03-2008, 10:35 AM
jamesweed's Avatar
jamesweed is on a distinguished road
I found this on cnczone ;
360*ipm/cir=?
I checked against my conversion program and its close??? This one may not take helix into it but it will get you close.
Old 09-03-2008, 10:42 AM
Moderator
Calculation of a ZC vector requires the length of the side opposite and the side adjacent. The Z vector length is plain enough. The C vector is calculated from circumferential distance (not a chord), and to do this you'll need to use a fraction of a circle, which is what you get when you calculate the circumference C, and multiply by C degrees/360 to get the arc segment length C'
Having those two sides, then you can calculate the hypotenuse using A^2 = Z^2 + C'^2
  #16   Ban this user!
Old 09-03-2008, 11:08 AM
g-codeguy is on a distinguished road
First, James, I can't afford that kind of calculator! Second, I probably couldn't program it if I could.
  #17   Ban this user!
Old 09-03-2008, 02:30 PM
HFD, 360 degrees at F360. equals one minute. You guys are trying to make me think. You're bad!
I'm swamped right now. No time to sit down, and give it some serious thought. Just wanted to let you know I am keeping track of your postings.
  #18   Ban this user!
Old 09-23-2008, 02:35 AM
dcoupar's Avatar
g-codeguy,
Don't know where you are on this problem, but I found the attached in a Daewoo/Doosan programming manual.
Hope it helps.
File Type: pdf Feed Rate Calculation for the Rotary Axis.pdf‎ (96.4 KB, 1248 views)
Last edited by dcoupar; 09-23-2008 at 02:37 AM. Reason: Forgot to attach the attachment.
Old 09-23-2008, 10:13 AM
Moderator
Good find, Dcoupar.
BTW, that 57.295° figure mentioned in the pdf is not some kind of black magic, it is simply the result of dividing 360/2Pi and is also known as 1 radian.
Quadrant marks at 90 degrees Mic6 Haas Mills 7 08-14-2008 12:52 PM
2 degrees of a learning Circle Smitty911 Dolphin CADCAM 4 02-12-2008 06:02 PM
how do i get sweep to do more than 360 degrees ??? yamaha_r1 Post Processors for MC 0 09-21-2007 09:41 AM
Controlling stepper motor, readout in degrees KC8QVO Stepper Motors and Drives 5 03-23-2007 03:34 AM
How to weld plate to tube at 90 degrees? coolman Welding, Brazing, Soldering, Sealing 12 12-23-2004 02:03 PM
