can't be done. the only way not to see these varables, is to protect program from edit or view.
On screen some macro variable can be seen
For exaple
#100
#500 like
I want; On screen not showed variable list
Example
#??? =100 but I dont want seen on screen.
Which is the #.... not showed screen
thanks
on the screen
#1 - #199
#500- #999 show it
Can I used #200 - #499 is it possible thank you very much
you can try...but i think you'll find, those varables don't exist...sorry
thank you
Osmanselim,
Standard 21iMB common variables #100 to #149 / #500 to #531
Optional common variables #100 to #199 / #500 to #999
ORDER #A02B-0286-J887 "ADDITION OF MACRO COMMON VARIABLE"
Thank you very much, for your information..
Hi,on fanuc 21i-tb the barrier menu is not seen.How can i activate barrier menu.What is the parameter of it and which byte should i change.
Thank you.
