Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 07-26-2008, 12:13 AM
Osmanselim is on a distinguished road
Ladder, can be write on pc?
Hi
I want;
Ladder diagram , read some macro variable and send to pc with "DPRNT" or different ladder code is it possible
I dont wants to write macro prg.
is it possible
thanks
Old 07-26-2008, 04:03 PM
Whobody Dont know?
Is my questation wrong?
Old 07-26-2008, 11:34 PM
guypb is on a distinguished road
I understand what you want to do, but you are better using macros. It's a lot easier and less likely to cause problems.
Old 07-27-2008, 04:38 AM
I used some macro in ladder
I used some macro for Operator Average
:7777
#501=#3011 (Date)
#502=#3012 (Current Time)
#503=#3901 (Number of Machined Parts)
#504=#4115 (Program Number)
DPRNT [#501 [54]]
But Operator same time chancing code
I want this program is hidden and never seen, never Changed
I think only ladder not easy changed and not easy understand
Now I want;
#501=#3011 (Date)
These codes added in the ladder diagram is it possible ?
Old 07-28-2008, 11:54 AM
jamesweed's Avatar
jamesweed is on a distinguished road
it probably is possible to edit your ladder to include these changes but i think you will need special software that is rather pricey. i think its called
Macro Compiler / Macro Executor or something like that. you could write your macro and save it under the 8000/9000 range that can be protected from edit or viewing.
Old 07-28-2008, 01:39 PM
stevo1 is on a distinguished road
Jamesweeed is right. That is the best way to do what you are trying to accomplish. Changing the ladder can be costly software and headaches to try and achive such a simple thing as what your tryin to do.
What kind of control are you using?
You can set it up in a 8000 or 9000 program number as a macro and even establish a G or M code to call that macro. Then you can lock those programs with a parameter so they can not be changed. There is also a parameter that locks the view of the program when it is running. So it would be like you want, out of sight and out of mind.
Stevo
Old 07-28-2008, 03:58 PM
thank you very much
My kontrol is Fanuc 21 iTB
I konw The 9000 program is not editing 3202
NE9 Which is the parameter not seen 9000 prg.
Many thanks
fanuc-o ladder Bill Clark Machine Problems, Solutions , Wireless DNC, serial port 9 09-29-2011 02:35 PM
Problem- ladder on the screen 0T guhl Fanuc 2 03-22-2008 03:57 AM
So whatsa ladder? Dancy General CNC (Mill and Lathe) Control Software (NC) 3 01-18-2008 05:57 PM
PMC-LADDER CHANDRU Fanuc 2 12-13-2007 10:17 PM
Ladder logic Chris Roth Deckel, Maho, Aciera, Abene Mills 4 12-26-2005 11:29 AM
