Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 07-09-2008, 11:07 AM
Osmanselim is on a distinguished road
create text file in macro
how can we create text file which includes some variables, with macro on cnc ?
Old 07-09-2008, 12:05 PM
Andre' B is on a distinguished road
If you mean to create a text file on a computer that contains data from the CNC control. The only (standard) way, standard being relative, is to have the computer connected to the control thru the serial port. And have a program running on the computer that will take input from the serial port and put it in a file. Then on the control you use the POPEN, BPRNT or DPRNT, and PCLOSE commands to output the data.
In the days of DOS the computer could be told to accept any input from the serial port as if it were coming from the keyboard in which case you would not need a program running on the computer, but I would have to dig deep to figure out how to do that, something with the mode command I think.
Old 07-09-2008, 05:18 PM
thank you Andre' B
Thank you very much for interesting
I have Solved
Problem is [54]
Who bady know What is the meaning [54]
Correct writing for me
:7777
#500=#3901
#501=#3011
#502=#3012
#503=#4115
POPEN
DPRNT[#500[54]]
PCLOS
M30
My Control is Fanuc 21 i TB
Thank you very much
Old 10-17-2008, 03:25 AM
padobranac's Avatar
padobranac is on a distinguished road
I have Solved
Problem is [54]
:7777
#500=#3901
#501=#3011
#502=#3012
#503=#4115
POPEN
DPRNT[#500[54]]
PCLOS
M30
Thank you very much
[54] means that there will be punched out 5 characters befor decimal point and 4 characters after decimal point
So if you have in variable 123456789.123456789
youl will get out 56789.1234
Sorry for bad english
How do I create a DFX file Blacksunshine DIY-CNC Router Table Machines 7 06-26-2008 08:32 PM
Text macro paptep Haas Mills 18 04-19-2007 07:48 AM
Text file with NC code - what's needed so that Mazak can run this? kevotron Mazak, Mitsubishi, Mazatrol 3 03-08-2007 03:45 PM
HOWTO: Create text in Radius Gujustud BobCad-Cam 1 03-22-2005 11:04 AM
Saving a Text file? Scott V BobCad-Cam 4 11-23-2004 09:27 PM
