Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 02-06-2012, 08:05 PM
pwilson101 is on a distinguished road
B-axis rotation - shortest route
We have a Mazak 630 horizontal machining center and the B-axis always rotates CW, when I would like it to rotate CCW sometimes (to take the shortest route). The programmer before me said he thought it was a parameter change, but wasn't sure and can't find the parameter book. (It sure sounds like it would be a parameter change).
Anyway, I was wondering if there could be a macro written for this. I'm a rookie when it comes to writing macros so was looking for some help. It a Mazak M32+ control.
Thanks for any help.
Old 02-06-2012, 08:26 PM
stevo1 is on a distinguished road
Hey Phil,
I posted this over in the machinetoolhelp forum for a different user name of "cncguy" but considering it is the exact same question I am going to post it here as well incase it helps anyone else.
Is it safe to ass u me that you are cncguy as well?? A lot of the same questions from 2 different users in 2 different forums.
I am not up on the Mazak programming lingo so I will not be able to help you with code. However a macro will not give you what you want. If you wanted to do shortest distance without the parameter change then you would have to program a B- or B+ from the position you are at or from B0.
Now the machines that I am familiar with will have a parameter setting for this which has already been pointed out to you. I would recommend finding the parameter manual online or by other means and simply setting the parameter and no additional programing is required. I have done this for all the rotary axis machines that I have setup.
In Fanuc controls it is determined by bit RINC which will move the rotary axis in the direction that is the least movement. I have also found setting bit RDAx for the rollover function. This way the control will not go past 360deg. Once it reaches 360 it will roll back over to 0 instead of adding to the 360deg.
Stevo
Old 02-06-2012, 08:45 PM
Yes, that would be me as well - trying to reach as many people as possible...and when and if I get the answers, I will always post them in all forums to help others. I think these forums are awesome and have been a great help to me as I'm trying to take my skills to a higher level.
Thanks for the info, as always...
- Paul
Old 02-07-2012, 07:17 AM
Sorry I could not be of more help. I just know the Fanuc bits for this. I am sure someone will have what you need.
Stevo
Need Help!- A axis rotation ???? dunnitagain Fadal 1 07-28-2011 07:50 PM
Route an Arc in the Z Axis ErikGun CNC Machining Centers 3 12-27-2010 01:27 AM
B axis rotation fitzpatrick2362 General Metalwork Discussion 0 10-12-2009 06:06 AM
X axis to A rotation quemast G-Code Programing 6 06-17-2006 08:36 PM
Shortest path between points? Software? jderou General CAM Discussion 2 12-22-2005 04:45 PM
