Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 02-06-2012, 07:54 PM
pwilson101 is on a distinguished road
Auto retract on CNC before drill burns up
Hi all,
Is there any way to write a macro that would make a drill automatically retract to the r-plane and stop with a message if it reaches a certain HP? I'm trying to save drills from burning up.
The macros would be Custom Macro B language, as we have fanucs, mitusbishi and mazak controls. I met a programmer awhile ago who said he wrote something for his machines like this, I never looked into it until now. How do you even get the information needed to write something like this?
Any help would be appreciated...
- Paul
Old 02-07-2012, 02:45 AM
fordav11's Avatar
fordav11 is on a distinguished road
HP? Hot and on Phire (fire)? If it gets to that point it's too late
Newer machines have load monitoring and you can program the machine with G-code to stop if the load is over the set limit.
If you don't have load monitoring it may be possible with more info from you but not by using the load meter because there is no current load reference variable in Fanuc macro.
More info means what is the condition where the drill would stop and return to the R level?
Old 02-07-2012, 06:48 AM
angelw is on a distinguished road
Originally Posted by pwilson101 View Post
Hi all,
- Paul
Hi Paul,
As pointed out by Ford, there are no Standard System Variables supplied by Fanuc to alloy Polling for Spindle or Axis load. Some MTBs supply additional System variables, but their supply is infrequent. Nakamura is one maker that I've seen supply System Variables for Axis Load.
What you want to do is possible by calling a Macro Program via an Interrupt Signal (UINT). When a tool abnormality is detected, processing to handle the abnormality is started by an external signal. To achieve this, you would have to add some hardware to monitor the load on the machining system. Axis load would be my choice, not Spindle load. If your machine has a Z axis load metre, it would be possible to tap into that circuit to trigger the Interrupt Signal.
An interruption type Custom Macro Function can be applied partway through a block. When the interrupt signal (UINT) is input, any movement or dwell being performed is stopped immediately and the interrupt program is executed.
Regards,
Bill
Need Help!- CO2 laser cutting white acrylic- burns VBLietuva Laser Engraving & Cutting Machines 13 01-26-2012 07:18 AM
fanuc ts20 resistor burns at startup joachim Fanuc 2 10-13-2011 05:01 PM
Tap retract kendo Okuma 16 01-09-2010 02:11 PM
Problem- Home made stepper circuit burns. boozeboy General Electronics Discussion 34 12-19-2008 08:56 PM
Fanuc drill macro with variable depth and fixed retract point trey88 Fanuc 4 10-26-2008 10:42 AM
