Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 11-28-2011, 02:30 PM
seven3 is on a distinguished road
Question co-ordinate rotation on a tombstone?
I need a macro to rotate the co-ordinate system as I rotate a tombstone on a 4th axis vmc. I thought it would be farly straightforward but now I,m ready to throw nyself down the stairs!! I did'nt take into account quite what was involved, if the part is not exactly over the center of rotation this affects the output and how in the world do I deal with negative rotational positions?
can anyone please help?
Old 11-28-2011, 03:03 PM
mfgbydesign is on a distinguished road
K&T Gemini controls had an "implied offset" where you could pick up the offset at one index position & the control would compensate X, Y, and Z as the B indexed.
I have yet to see this option available on another control.
You could probably do it with a macro depending on what control you have. I know Kurt does this on their vise bodies as I had to incorporate the macro calls into the programs I wrote for them. Frankly I thought it was huge waste of time as the bodies were all machined on dedicated fixtures and the macro does NOT compensate for machine geometry error.
Old 11-28-2011, 03:19 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
you need to set your macro to use the offset position of the x and z from the center of rotation , program header is the best place to add these variables ,
eg:
o00023
(header)
#101= 1.025 (Y offset A0)
#102= -.5 (Z distance between tool probe and part z zero @ A0)
#103= 0 (ANGLE)
#120= -2.525 (SHIFT FROM TOOL PROBE T0 Z0 AT A0 center of rotation)
#103= 90. (rotation)
M97 P8989 (macro sub call)
G52 X-6. Y#109 Z#110
g0 a#103
main program
if your qualifying tools from the top of the part then scratch the toolprobe and set z variable(eg #102) as the distance from the center of rotation
,then you'll need to do some addition , subtraction and a bit of trig in your macro in order to calculate the new rotated position , its not too bad once you get your head wrapped around it
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Siemens Co-ordinate rotate 810M Control stroker49 CNC Machining Centers 0 07-18-2011 07:10 PM
Tombstone jcnewbie Mastercam 5 11-13-2009 02:43 PM
multiple co-ordinate systems kccrusher Cincinnati CNC 3 10-13-2009 02:26 AM
Variaxis co-ordinate rotation help out2thow Mazak, Mitsubishi, Mazatrol 0 06-25-2007 08:25 PM
Work Co-ordinate Systems? Keeps spitting out code in g56... peter.blais Mastercam 7 07-09-2006 12:51 PM
