Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 06-22-2011, 12:42 PM
camtd is on a distinguished road
M98 Looping
I was wondering if there is a way to add a statement to have the flexibilty of having the G91 C30. start at another location if wanted in the loop?
Ex. Start a C90 position instead of from the beginning. I have a example below.
I am trying to work around my Cam system and post not being able to post a G66 which is my machining info and a M98 which is my positon info.
O1000
N10 G54 X0 Y0 Z5.0
N20 (TOOL-2-.125-FINISH-ENDMILL)
N30 T2
N40 M6
N50 M8
N60 G90 G17 G0 X2.0878 Y.2118 C0. S3820 M3
N70 G43 Z5. H2
N80 M98 P5 L5
N90 M9
N100 G91 G28 Z0
N110 M30
N120
O5
N10 ( SUB NUMBER: 5 )
N20 ( OPERATION 6: CONTOUR )
N30 G91 C30.
N40 G90 G0 X2.0878 Y.2118
N50 Z1.228
N60 G1 Z1.063 F10.
N70 G41 X2.0035 Y.2656 D52
N80 X1.9439 Y.3037
N90 X1.9369 Y.3021 F20.
N100 X1.9298 Y.3004
N110 X1.9227 Y.2973
N120 X1.9086 Y.2875
N130 X1.9026 Y.2826
N140 X1.8985 Y.2755
N150 X1.8943 Y.2684
N160 X1.8921 Y.2613
N170 X1.8895 Y.2331
N180 X1.8899 Y.226
N190 X1.904 Y.0069
N200 X1.9042 Y-.0002
N210 X1.9039 Y-.0072
N220 X1.8899 Y-.2264
N230 X1.8895 Y-.2334
N240 X1.8921 Y-.2617
N250 X1.8945 Y-.2686
N260 X1.9028 Y-.2829
N270 X1.9086 Y-.2875
N280 X1.9227 Y-.2973
N290 X1.9298 Y-.3004
N300 X1.9369 Y-.3021
N310 X1.9439 Y-.3037
N320 X2.0036 Y-.2657
N330 G40 X2.0879 Y-.2119
N340 G0 Z5.
N350 M99
Old 06-22-2011, 03:45 PM
ProProcess is on a distinguished road
Instead of C30. you could say C#100 and set #100 to whatever you would like.
Control the process, not the product!
Machining is more science than art, master the science and the artistry will be evident.
Old 06-23-2011, 02:29 PM
This is what I came up with so far. I am reading and trying things as I go. I was wondering if there is a way to clearout the angle offset after it is used once? I am not sure of the format I would need.
Thank You
O0001 ( TEST )
N10 ( DATE - 23-06-11 TIME - 13:34 )
N20 G20
N30 G0 G17 G40 G80 G90 G94 G98
N40 G0 G28 G91 Z0.
N50 G0 G28 X0. Y0.
( ENDMILL-.750 )
N70 T3
N80 M6
N90 G0 G54 G90 X2.3232 Y.1768 C0. B0. S203 M3
N100 G43 H3 Z.25 M8
N110 Z.2
( F=ANGLE-OFFSET-TO-RESTART-WHERE-NEEDED-0.0-IS-DEFAULT )
N120 G65 P1001 L4 A15.0 F0.0
N200 M9
N210 M5
N220 G0 G28 G91 Z0.
N230 G0 G28 X0. Y0.
N240 G28
N250 M30
( SUBPROGRAM-MILL-4-HOLES )
O1001
N090 #102=#7
N100 #101=#1
N110 G91 C#101+#102
N115 G90
N120 G1 Z-1.5 F6.
N130 G3 X2.25 Y0. I.1768 J-.1768 F.81
N140 X2.5 Y-.25 I.25
N150 X2.75 Y0. J.25
N160 X2.5 Y.25 I-.25
N170 X2.3232 Y.1768 J-.25
N180 G1 Z-1.3 F100.
N190 G0 Z.25
M99
Old 06-27-2011, 08:48 AM
Thank You
O0001 ( TEST )
N20 G20
N40 G0 G28 G91 Z0.
N50 G0 G28 X0. Y0.
( ENDMILL-.750 )
N70 T3
N80 M6
N100 G43 H3 Z.25 M8
N110 Z.2
N200 M9
N210 M5
N220 G0 G28 G91 Z0.
N230 G0 G28 X0. Y0.
N240 G28
N250 M30
O1001
N090 #102=#7
N100 #101=#1
N110 G91 C#101+#102
N115 G90
N120 G1 Z-1.5 F6.
N150 X2.75 Y0. J.25
N180 G1 Z-1.3 F100.
N190 G0 Z.25
#7=0(SET OFFSET TO 0 FOR SUBSEQUENT ITERATIONS)
M99
See the red text above, this would set it to 0 at the end of the first loop.
To clear a variable i.e make it's value empty you would set it to #0.
HTH
Good luck
Old 06-27-2011, 08:59 AM
TURNER is on a distinguished road
Thank You
O0001 ( TEST )
N20 G20
N40 G0 G28 G91 Z0.
N50 G0 G28 X0. Y0.
( ENDMILL-.750 )
N70 T3
N80 M6
N100 G43 H3 Z.25 M8
N110 Z.2
N200 M9
N210 M5
N220 G0 G28 G91 Z0.
N230 G0 G28 X0. Y0.
N240 G28
N250 M30
O1001
N090 #102=#7
N100 #101=#1
N110 G91 C#101+#102
N115 G90
N120 G1 Z-1.5 F6.
N150 X2.75 Y0. J.25
N180 G1 Z-1.3 F100.
N190 G0 Z.25
M99
Hi Camtd,
Or you could still use M98 (i think like this )
O0001 ( TEST )
N20 G20
N40 G0 G28 G91 Z0.
N50 G0 G28 X0. Y0.
( ENDMILL-.750 )
N70 T3
N80 M6
N100 G43 H3 Z.25 M8
N110 Z.2
#500=0( START ANGLE-OFFSET-TO-RESTART-WHERE-NEEDED-0.0-IS-EFAULT)
#501=20.0( PITCH)
#502=4( REPEATS )
N120 M98 P1001 L#502
N200 M9
N210 M5
N220 G0 G28 G91 Z0.
N230 G0 G28 X0. Y0.
N240 G28
N250 M30
O1001
N110 G91 C#501
N115 G90
N120 G1 Z-1.5 F6.
N150 X2.75 Y0. J.25
N180 G1 Z-1.3 F100.
N190 G0 Z.25
M99
Just edit the values in green.
Good luck,
Keith.
Old 06-30-2011, 12:06 PM
Both options are great
I did not expect to learn so much.
I seems when I read the books my eyes get a glaze over them and I just get more confused.
How would a statement look if I wanted to say
If #500 in not equal to #501/360 then print a error on the screen "starting angle not dividable by 360 degrees"
Thank You
Old 06-30-2011, 12:44 PM
Thank You
Explain a little more about what you want.
What do you not want #501 to be?
I am assuming that you do not want fractional angle such as #501=32.423
But you know what "they" say about assuming.
Old 06-30-2011, 02:44 PM
I would like #501 to be 15 degrees
Old 07-01-2011, 08:05 AM
I added what I think is all but the one thing which is to make sure the distance is divisible by 15 in the correct way.
Thank You
O0001 ( TEST )
N20 G20
N40 G0 G28 G91 Z0.
N50 G0 G28 X0. Y0.
( ENDMILL-.750 )
N70 T3
N80 M6
N100 G43 H3 Z.25 M8
N110 Z.2
#500=0( START ANGLE-OFFSET-TO-RESTART-WHERE-NEEDED-0.0-IS-DEFAULT)
N200 M9
N210 M5
N220 G0 G28 G91 Z0.
N230 G0 G28 X0. Y0.
N240 G28
N250 M30
O1001
#501=20.0( PITCH)
#502=4( REPEATS )
#503=15/360 (NOT SURE WHAT LOGIC TO PUT HERE
IF[#500NE#503] GOTO N777
N777
M5
#3000= (MODIFED POSTION IS NOT CORRECT)
N110 G91 C#501
N115 G90
N120 G1 Z-1.5 F6.
N150 X2.75 Y0. J.25
N180 G1 Z-1.3 F100.
N190 G0 Z.25
M99
Old 07-01-2011, 08:58 AM
A few things,
You've moved this...
Code:
#501=20.0( PITCH)
#502=4( REPEATS )
into the sub program but it needs to be in the main program ahead of the M98 call.
Otherwise the number of repeats will not be read on your first time through the loop because #502 is not set untill you're in the sub program.
Too the logoic will be fired on every iteration of the loop, which is usually not necessary or desired.
Now onto the error trapping...
Do you want the offset angle to be limited to 15° or divisibile by 15°.
  #11   Ban this user!
Old 07-01-2011, 09:01 AM
I would like it divisible by 15.
  #12   Ban this user!
Old 07-01-2011, 09:14 AM
Code:
#503=#500 MOD 15
IF[#500EQ0]GOTO777(I ASSUME 0 IS OK TO USE)
IF[#503EQ0]GOTO777(NO REMAINDER/DIVISIBLE BY 15)
#3000=1(#500 IS NOT 0 OR DIVISIBLE BY 15)
N77730
I did not test this on a machine but it should be good
Parametric Looping problem gtrrpa Parametric Programing 12 11-15-2010 05:03 PM
Looping command? rigo430 Haas Lathes 1 04-11-2010 05:35 PM
LOOPING? with Camsoft?? nelZ CamSoft Products 15 10-15-2008 03:56 PM
Program Looping Bohemund CamSoft Products 7 05-26-2007 11:08 AM
Sub Looping murphyspost Daewoo/Doosan 8 12-27-2006 10:28 AM
