Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 06-01-2011, 02:12 PM
gtrrpa is on a distinguished road
Tapping Macro ? Is it possible ?
Hi All ! We bought a used Mori Seki CL203 Lathe. Tried to tap on it using G32 and it closed up the hole by .01 to .015. We called the seller and he said you cant Rigid Tap or use G32 on this machine. So my question is, Is it possible to create a macro or longhand program for a 5/16-24 thread? And if the lathe is not syncing with the F word in the G32 code would the program have to be a macro or longhand ? Possibly I'm screwed and have to use a floating tap which I'm trying to stay away from. Thanks In Advance....
Old 06-01-2011, 06:27 PM
dpuch is on a distinguished road
I think you have a problem unless you can find some way to sync using macro tricks with G/M codes. Perhaps something to do with single point threading...
The rest of it should be easy to program as a macro.
Old 06-01-2011, 10:50 PM
I hear what your saying. Thats the whole problem. How would I attempt to try to single point using a tap ? No pull out. Then I have the same problem that I have now with the tap pulling the material.
Old 06-03-2011, 06:25 AM
sinha_nsit is on a distinguished road
You have to use floating tap holder, with G32.
It is not that G32 cannot be used.
Rigid taps can only be used if you have rigid-tapping option on your machine.
Macro would be of no help with regard to synchronization, in the absense of rigid-tapping.
Old 12-09-2011, 08:13 AM
MCImes is on a distinguished road
On my swiss lathe I use this macro to cross tap as the cross tools dont have the rigid tap option. It works like a charm.
As stated above you need to use a floating tap holder.
#100=250 (RPM)
#101=.025 (FEED)
#102=[#100*#101]
G0 G98 X# Z# M23S#100
C0.
G4U.5
G1X-.36F#102
M24S#100
G4P5
X.3
G0X1.496 T0
if you're using it on a lathe you would need to change x with z. also you'll probably need to change m23 to m3 and m24 to m4
I program, setup and run Swiss lathes with Fanuc controls
tapping on a mini mill without rigid tapping??? mls Haas Mills 13 07-03-2009 06:43 PM
Tapping with the Tormach Tapping Head bobs_charger Tormach PCNC 0 04-24-2009 04:08 PM
Testing program for Macro (Fanuc Macro B) NickDP Fanuc 2 03-27-2009 03:15 PM
Convert Fanuc Macro to Fadal Macro bfoster59 Fadal 1 11-08-2007 11:41 PM
tapping head vs hand/cordless tapping machine.... InspirationTool General Metal Working Machines 6 09-12-2005 08:10 PM
