| Parametric Programing (custom macro b, fadal macro, okuma user task) |
Thanks for all the looks at my julian date engraving question. I still have no solution. Todays problem is this: I need to do helical interpolation on a tapered hole. Actually I want to make a straight hole tapered by interpolation. On my Mazak HCN 6000 (running in EIA--0M Fanuc clone) I can do helical interp. easily with g2.1 or g3.1 (using a P value for z move per full circle), But I need to make diameter decrease by an 8:1 ratio (1/8" per 1"). I'm relatively new to parametric programming, but there must be a fairly easy solution. (custom macro b) Thanks for looking....any opinions would be appreciated. |
| Take a look at samu's post #14 http://www.cnczone.com/forums/fanuc/...3_fanuc-2.html Bear in mind this method will not produce a perfect spiral, but I used the technique along with a Z feed to successfully rough out an insanely deep bore with a feedmill by creating a very slow taper. Other options are 'involute' interpolation - if you have it... I wrote a custom b macro that can do this kind of thing in linear increments. I have the luxury of a pretty decent look-ahead speed, but the 'resolution' can be adjusted to optimise the feedrate. Give us a shout if you want to try it... DP |
| Anyone interested also take a look at http://www.cnczone.com/forums/parame...engraving.html starting at post #10 |
| Newbie- tapered hole | o1dakota440 | Mach Wizards, Macros, & Addons | 2 | 07-22-2011 05:24 PM |
| Newbie Circular Interpolating | eliot15 | General Metalwork Discussion | 3 | 12-05-2010 05:55 AM |
| Need Help Mazak T32-3 Circular Interpolating | dcorrick | Mazak, Mitsubishi, Mazatrol | 0 | 07-20-2009 03:10 PM |
| Hole Comes out Tapered HELP. | Cartierusm | General Metalwork Discussion | 21 | 07-12-2009 08:09 AM |
| tapered hole | dshowald | Milltronics | 5 | 05-01-2007 11:19 AM |
