Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 04-07-2011, 06:23 PM
xj0696 is on a distinguished road
haas threading macro
looking to write a macro for lathe to cut any thread wondered if there was one already out there
Old 04-07-2011, 07:54 PM
What is wrong with the G76 threading cycle? It is really just a macro embedded in the machine controller system. You have to enter parameters related to your desired thread just the same as you would need for any other macro.
Old 04-07-2011, 07:59 PM
this macro would be for multiple or single lead threading for people who have little to no programming experience. and it would be that much faster for me
Old 04-07-2011, 08:02 PM
If they have little or no programming experience how can you trust them to enter the correct values into a macro?
Old 04-07-2011, 08:04 PM
comments next to the variables that need to be defined
Old 04-08-2011, 03:20 AM
sinha_nsit is on a distinguished road
Comments can be added to G76 block also.
The most important thing is that no-one can possibly write macros incorporating full functionality of such a canned cycle, in a reasonable time frame.
No wonder these are options, sometimes.
G76 can be used for multi-start threads also. The trick is to axially shift the start point of the next helix by pitch distance. F-word would be lead.
Haas Macro kenickie22 Haas Mills 9 11-21-2010 11:03 PM
Newbie- Macro problem with Haas VF-1 and HS-1 colton_m Haas Mills 6 03-04-2010 11:02 PM
Soliciting Haas Macro Advice mcmachining G-Code Programing 4 07-28-2009 12:07 PM
Need Help!- How to make 2"1/2 NPT left hand threading on Haas SL-20 parktoshi Haas Lathes 2 04-08-2009 05:27 PM
Lefthand threading on a Haas Tl2 Peter Gibbs Haas Mills 5 07-28-2006 08:25 PM
