Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 03-19-2011, 10:14 AM
Jonnis is on a distinguished road
Npt thread mill macro
Hello
Anyone have macro for milling NPT threads on a fanuc marco b?
The machine is a mori seiki nt4300 whitout the option to mill spirals(damn fanuc for taking money for every thing)
Or a program that mills a spiral that i can rewrite to move i z too?
Old 03-20-2011, 02:56 PM
christinandavid's Avatar
christinandavid is on a distinguished road
I have a macro b program that can perform this kind of motion using small linear increments.
It is a very open ended cycle and tapered thread milling is not its only application, so as it is you would have to know and input your start and finish diameter, start and finish Z and number of revolutions (of course, it could be modified later to work out the above using the angle of taper if you wish).
If you think your control is fast enough to process it (there is about ten simple calcs per movement) let us know the particulars of your thread and cutter and I will post it with an explanation. Note that the way it is written means that you will need to have 100 common macro variables available.
DP
Old 03-21-2011, 07:51 PM
Kiwi is on a distinguished road
Originally Posted by Jonnis View Post
....Or a program that mills a spiral that i can rewrite to move i z too?
This VB program may help.
Tags
fanuc, macro, mill, npt
THREAD MILLING MACRO cmo Haas Mills 7 12-18-2010 09:49 PM
Face mill macro? mmachining Haas Mills 2 10-10-2008 06:42 AM
Thread mill external NPT thread cutting edge General Metalwork Discussion 11 09-15-2008 08:33 AM
Continuous thread G32 macro dcrace G-Code Programing 3 05-29-2007 02:23 PM
Kia bore mill macro WILLMC General Metalwork Discussion 0 10-14-2005 11:56 AM
