Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 03-11-2011, 11:06 PM
springer82 is on a distinguished road
family of parts???
Hi Everyone. I could use some help with sys variables. I'm new to macro programming. I am trying to set the tool length offset of 5 tools to one variable.
N5IF [#101NE1.] GOTO6
#7=#2003
When I set the TLO using #2003 for tool #3 and #2004 for tool #4,,, I get an error message. "Can not find Number” Something like that anyway. I am setting #7 to whatever tool I am using then using #7 as my H# in the program. In my manual (Fanuc 16i-M) it tells me that the TLO #'s are stored in these variables. With the alarm that I get I wonder if I have the right location??? Can anybody point me in the right direction. That would be great. Thanks for your time.
Old 03-12-2011, 09:10 AM
dcoupar's Avatar
The system variable for the tool length offset differs depending what type of offset memory (A, B, or C), and how many offsets your control has.
Most of the recent Fanuc's I've seen are either B or C, both of which use #11003 for the Tool length Geometry for H3 and #10003 for the Wear. I would try
#7=#11003
also, for backward compatability, you can use #2203 instead of #11003.
If you have over 200 offsets, you can get the values > 200 starting at #11201
Old 03-12-2011, 11:47 AM
family of parts???
Hi dcoupar,
Yes I was using memory A. That would explain why it could not find the #.
I will rewrite my program and try it out first thing Monday. One more question for ya. I am very new to macro programming. Please forgive the simple questions. Under memory "B" I see tool 1's memory spot is listed as #11001 (#2201) You called it backward compatability. What is the difference? Thanks for your time.
#7=#11003
Old 03-12-2011, 06:57 PM
dcoupar's Avatar
If you have old macros that used #2203, #2204 etc. they will still run on the 16i.
Old 03-15-2011, 05:50 AM
sinha_nsit is on a distinguished road
see the attachment for more information on memory type C offset numbers.
File Type: pdf system variables for milling machine offsets.pdf‎ (38.1 KB, 38 views)
Searching for family crest DXF. art FVRacer5 CNCzone Club House 11 06-25-2010 01:47 PM
Another new JGRO family member Fragge JGRO Router Table Design 14 04-06-2010 02:52 PM
Family of Similiar Parts Macro Capt Crunch Parametric Programing 3 06-09-2009 08:14 PM
Family crest files FVRacer5 Machine Created Art 6 01-05-2009 09:21 AM
new member in the family praveen224 CNCzone Club House 2 09-27-2006 04:59 PM
