Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 02-26-2011, 08:06 AM
bamstik is on a distinguished road
biesse 336 parametric question
I have this old girl for a while now and have been using Mastercam all along.
I am trying to figure out how to pocket in a small program. With the machines manual it is not like walking in the park. I spat out this program in Mastercam and ran it the tool config is set. Below N58 i think i will be able to change it to the lpx+lpy commands with no problem.N14-N56 is the problem?
I will be doing all lengths and widths so using Mastercam sucks if you have to post half your day away. Attachment is in notepad
Thanks in Advance
Dan
Old 02-26-2011, 06:25 PM
Add on
Not expecting a freebie,just dont get it (tested working file in prev.post)
A Shaker Door 3/4 MDF, 2 1/4 rail all around, 1/4 Deep pocket, Four tools
N10 LX=406.30 LY=304.70 LZ=18 HC1 Z-PRK
N20 PAN=1 UT=1 L=GCUA
N30 PAN=2 UT=2 L=GCUA
N40 AA=LPX-66.00
N50 BB=LPY-66.00
N60 cc=(Y-17.150) : stepover amount
N70 DD=(LPY-133.2/17.150) :# of passes
N80 X66.60 Y=AA Z=PRK TP2 PRF=-!) G40 F3 L=PON
N90 G1 ZI11.00
N100 EE=0
:1
N110 EE=EE+1
N110 JM(EE>=DD):2
N120 G1 X66.60 Y=BB
N130 G1 Y=CC
N140 G1 X66.60
N150 JM:1
N160 G0 ZI-11
:2
N170 AND SO ON........ I know its out a mile ..........Machine thinks so too.
Old 02-28-2011, 04:00 AM
battwell is on a distinguished road
N71 TD=19/2 ;TOOL DIAMETER/2
N40 AA=LPX-66.00-TD
N50 BB=LPY-66.00-TD
N60 cc=(TD*1.5)/2 ; stepover amount
N70 DD=LPY-(2*AA) ;# of passes
N80 X66.60+TD Y=66.6+TD Z=PRK TP2 PRF=0 G40 F3 L=PON
N90 G1 ZI 6.00
N100 EE=0
:1
N110 EE=EE+1
N110 JM(EE>=DD):2
N120 G1 X=AA
N130 YI=CC
N140 G1 X=66.6+TD
N141 YI=CC
N150 JM:1
:2 ;CLEANUP EDGE PASS
N160 G1 X=66.6+TD Y=BB
N161 G1 X=AA
N162 G1 Y=66.6+TD
N163 G1 X=66.6+TD
N164 G1 Y=BB
so much to learn, so much to pass on.
Old 02-28-2011, 06:42 PM
Thanks for replying on my little headache,I studied your output and tried running it.
With it, Issues i am having are,
N110 to N150 .The JM(EE>=DD):2 Does not count down unless i add JM(EE>=DD/14.25):2 this way i get a full toolpath in work area.
Since i have a steppover of 7.125, The program jumps two steps in X in the loop and i can not finish the pocket without being short one tool pass in the X axis. Even if pannel sizes are increased with different stepovers not quite right."Not smooth like Molson Canadian"
I could run it like this with two cleanup passes, but that bits.
Dan
Old 03-01-2011, 04:41 AM
i didnt run the code. just altered yours on screen, after a few beers.
never expected it to run fully first time :-)
i normally would work out number of passes then subtract one every loop, then when its 0 make the jump
might work better if i put the /2 on the right line
N60 cc=(TD*1.5) ; stepover amount ; 75%tool stepover
N70 DD=(LPY-(2*AA)/2)/cc ;# of passes
divided by 2 as the toolpath in loop gives 2 passes in x , not 1
hopefully that will get you a bit closer
it may still need tweeking and hopefully you can follow what its doing.
having a biesse you have to do code like this . its a pain
try doing this! YouTube - Biesse "duzzit" cnc . fast oak roughing (love part1)
Old 03-01-2011, 01:57 PM
Thanks again
I was looking only in the box not outside.(loop)
I added line N104 to complete the pass after the loop,and "wam" there it was,
I will attach final program if you want to try it, just check your tool config depths.
The reason i posted was that i didn't do a (loop) for at least ten years,didn't know if it was right since all i use is Mastercam and it will "Not" do parametric.
Thanks again for your help
Dan
Old 03-01-2011, 04:10 PM
glad its working.
on 480 control, what is the maximum program size you can run?
how do you interface yours with mastercam?
Biesse rover 316 controller ID question 67barracuda CNC Machining Centers 9 11-13-2011 11:16 AM
Parametric programming question. chrisryn Parametric Programing 12 05-27-2008 12:04 PM
parametric question PaintItBlue Haas Mills 5 01-05-2008 07:05 PM
parametric programs DaveN Deckel, Maho, Aciera, Abene Mills 4 11-22-2007 06:55 AM
Parametric Programming widgitmaster BobCad-Cam 7 05-04-2006 01:04 PM
