Results 1 to 7 of 7
Thread: How do the F and A variables work?
    Nov 2005
    Can anyone explain how the following work together? Is there something that is programmed at the Fanuc control that is not in this program?
    Thank You
    N190 G66 P2353 F1.5 A2.9
    N560 G65 P2356 F3.9 (DIA. OFFSET IN SUB PROG.)
    N700 G65 P2358 F3.9 (DIA. OFFSET IN SUB PROG.)
    N840 G65 P2360 F2.0 (DIA. OFFSET IN SUB PROG.)
    O2353 (ROUGH)
    N10 M10
    N20 G0 X-3.768 Y0
    N30 G1 Z0.48 F200.
    N40 Z0.225 F#9
    N50 Z0.48 F200.
    N60 X-3.653 Y0
    N70 Z0.225 F#9
    N80 Z0.49 F200.
    N90 X-3.538 Y0
    N100 Z0.225 F#9
    N110 Z0.54 F200.
    N120 X-3.423 Y0
    N130 Z0.225 F#9
    N140 Z.63 F200.
    N150 X-3.308 Y0
    N160 Z0.225 F#9
    N170 Z.77 F200.
    N180 X-3.2275 Y0
    N190 Z0.225 F#9
    N200 X-3.66 Y0 F#1
    N210 G0 Z4.
    N220 M11
    N230 M99
    O2358 (Mill .255 slots)
    N10 M10
    N20 G0 X-11. Y0.
    N30 Z3.
    N40 G1 Z1.525 F100.
    N50 X-10.5495 F#9
    N60 Z2.0 F100.
    N70 X-11. Y0.
    N80 Z1.520
    N90 G41 D4 X-10.912 Y-0.0103 F#9 (DIA. OFFSET)
    N100 X-10.88 Y-.0103
    N110 X-10.5495
    N120 G3 X-10.5495 Y0.0103 I0. J0.0103
    N130 G1 X-10.92
    N140 G0 Z4.
    N150 G40 X-11. Y0.
    N160 M11
    N170 M99
    O2351
    (PROG.REV.- 10/23/2010)
    (**** G54 ****)
    (**** Z = 0 SURFACE -A- ****)
    (**** COVER ON TOP. ****)
    N10 G0 G17 G28 G49 G80 G91 G94 G97 Z0
    N20 M303
    N30 G91 G40 G28 X0 Y0
    N40 M69
    N50 G28 B0
    N60 M68
    N70 M11
    N80 G0 G90 G54 C0. (WORK OFFSET)
    N90 M10
    N100 M1
    (T1 .5DIA. ENDMILL - ROUGH)
    N110 T1
    N120 M6
    N130 M69
    N140 G0 G90 G54 B0. (WORK OFFSET)
    N150 M68
    N160 M11
    N170 G0 G90 X-3.25 Y0 C0. M3 S460
    N180 G43 Z2. H1 M8
    N200 M98 P2352
    N210 G67
    N220 G0 G28 G49 Z0. M9
    N230 G0 G40 X-5. Y0 M5
    N240 M00
    (T2 END MILL 0.5 DIA /.035RAD. FINISH )
    N250 T2
    N260 M6
    N270 M69
    N280 G0 G90 G54 B0. (WORK OFFSET)
    N290 M68
    N300 M11
    N310 G0 G90 X-4.1 Y0 C0. M3 S500
    N320 G43 Z2. H2 M8
    N330 G41 D2 X-4.05 Y-.01 (DIA. OFFSET)
    N340 G65 P2354 F2.
    N350 M98 P2352
    N360 G67
    N370 G0 Z2.
    N380 G0 G40 X-4.1 Y0
    N390 Z0.5
    N400 G41 D2 X-4.05 Y-.01 (DIA. OFFSET)
    N410 G65 P2355 F2.
    N420 M98 P2352
    N430 G67
    N440 G0 G28 G49 Z0. M9
    N450 G0 G40 X-5. Y0 M5
    N460 M00
    N470 M00
    (**** G55 ****)
    (**** Z = 0 CENTER OF PART****)
    (******* CLAMP THRU HOLES & REMOVE COVER *******)
    (T3 .3125 DIA End Mill R.055)
    N480 T3
    N490 M6
    N500 M69
    N510 G0 G90 G55 B90. (WORK OFFSET)
    N520 M68
    N530 M11
    N540 G0 G90 X-4.1 Y0 C0. M3 S970
    N550 G43 Z4. H3 M8
    N570 M98 P2357
    N580 G67
    N590 G0 G28 G49 Z0. M9
    N600 G0 G40 X-5. Y0 M5
    N610 M00
    (T4 .2344 DIA End Mill R.045)
    N620 T4
    N630 M6
    N640 M69
    N650 G0 G90 G55 B90. (WORK OFFSET)
    N660 M68
    N670 M11
    N680 G0 G90 X-11. Y0 C0. M3 S1300
    N690 G43 Z4. H4 M8
    N710 M98 P2359
    N720 G67
    N730 G0 G28 G49 Z0. M9
    N740 G0 G40 X-5. Y0 M5
    N750 M00
    (T5 .1406 DIA End Mill)
    N760 T5
    N770 M6
    N780 M69
    N790 G0 G90 G55 B90. (WORK OFFSET)
    N800 M68
    N810 M11
    N820 G0 G90 X-11. Y0 C0. M3 S1700
    N830 G43 Z4. H5 M8
    N850 M98 P2357
    N860 G67
    N870 G0 G28 G49 Z0. M9
    N880 G0 G40 X-5. Y0 M5
    N890 M00
    (T6 .0625 DIA End Mill)
    N900 T6
    N910 M6
    N920 M69
    N930 G0 G90 G55 B90. (WORK OFFSET)
    N940 M68
    N950 M11
    N960 G0 G90 X-11. Y0 C0. M3 S1700
    N970 G43 Z4. H6 M8
    N980 G65 P2361 F4.2 (DIA. OFFSET IN SUB PROG.)
    N990 M98 P2357
    N1000 G67
    N1010 G0 G28 G49 Z0. M9
    N1020 G0 G40 X-5. Y0 M5
    N1030 M00
    (**** G56 ****)
    (**** Z = 0 ON SURFACE BEING DRILLED****)
    (T7 #4 CENTERDRILL )
    N1040 T7
    N1050 M6
    N1060 M69
    N1070 G0 G90 G56 B78. (WORK OFFSET)
    N1080 M68
    N1090 M11
    N1100 G0 G90 X-6.9359 Y0 C0. M3 S1500
    N1110 G43 Z1. H7 M8
    N1120 G81 G98 Z-.2 R.1 F3.
    N1130 M98 P2362
    N1140 G80
    N1150 G0 G28 G49 Z0. M9
    N1160 G0 G40 X-5. Y0 M5
    N1170 M00
    (T8 .375 DIA. DRILL )
    N1180 T8
    N1190 M6
    N1200 M69
    N1210 G0 G90 G56 B78. (WORK OFFSET)
    N1220 M68
    N1230 M11
    N1240 G0 G90 X-6.9359 Y0 C0. M3 S700
    N1250 G43 Z1. H8 M8
    N1260 G81 G98 Z-.55 R.1 F1.4
    N1270 M98 P2362
    N1280 G80
    N1290 G0 G28 G49 Z0. M9
    N1300 G0 G40 X-5. Y0 M5
    N1310 M00
    (T9 .375 DIA End Mill - SEMI .685)
    N1320 T9
    N1330 M6
    N1340 M69
    N1350 G0 G90 G56 B78. (WORK OFFSET)
    N1360 M68
    N1370 M11
    N1380 G0 G90 X-6.9359 Y0 C0. M3 S700
    N1390 G43 Z4. H9 M8
    N1400 G65 P2363 F1.4
    N1410 G0 C0.
    N1420 M98 P2362
    N1430 G67
    N1440 G0 G28 G49 Z0. M9
    N1450 G0 G40 X-5. Y0 M5
    N1460 M00
    (T10 .375 DIA End Mill - FINISH)
    N1470 T10
    N1480 M6
    N1490 M69
    N1500 G0 G90 G56 B78. (WORK OFFSET)
    N1510 M68
    N1520 M11
    N1530 G0 G90 X-6.9359 Y0 C0. M3 S700
    N1540 G43 Z4. H10 M8
    N1550 G65 P2364 F1.4
    N1560 G0 C0.
    N1570 M98 P2362
    N1580 G67
    N1590 G0 G91 G28 G49 G80 Z0 M11
    N1600 G91 G28 X0. X0.
    N1610 G91 G28 C0.
    N1620 M10
    N1630 M69
    N1640 G91 G28 B0
    N1650 M68
    N1660 G91 G30 X0 Y0
    N1670 G30 Z0
    N1680 M33
    N1690 G0 G91 G28 Z0
    N1700 G91 G28 X0. X0.
    N1710 M30
    ( -REV.- - DATED - -CHANGES )
    ( - 10/23/2010 ORIGNIAL RELEASE )
    O2352 (28 COUNTERBORES)
    N10 C0.
    N20 C12.8571
    N30 C25.7143
    N40 C38.5714
    N50 C51.4286
    N60 C64.2857
    N70 C77.1429
    N80 C90.
    N90 C102.8571
    N100 C115.7143
    N110 C128.5714
    N120 C141.4286
    N130 C154.2857
    N140 C167.1429
    N150 C180.
    N160 C192.8571
    N170 C205.7143
    N180 C218.5714
    N190 C231.4286
    N200 C244.2857
    N210 C257.1429
    N220 C270.
    N230 C282.8571
    N240 C295.7143
    N250 C308.5714
    N260 C321.4286
    N270 C334.2857
    N280 C347.1429
    N290 M99
    O2353 (ROUGH)
    N10 M10
    N20 G0 X-3.768 Y0
    N30 G1 Z0.48 F200.
    N40 Z0.225 F#9
    N50 Z0.48 F200.
    N60 X-3.653 Y0
    N70 Z0.225 F#9
    N80 Z0.49 F200.
    N90 X-3.538 Y0
    N100 Z0.225 F#9
    N110 Z0.54 F200.
    N120 X-3.423 Y0
    N130 Z0.225 F#9
    N140 Z.63 F200.
    N150 X-3.308 Y0
    N160 Z0.225 F#9
    N170 Z.77 F200.
    N180 X-3.2275 Y0
    N190 Z0.225 F#9
    N200 X-3.66 Y0 F#1
    N210 G0 Z4.
    N220 M11
    N230 M99
    O2354 (SEMI .010 STOCK)
    N10 M10
    N20 G1 Z0.2125 F100.
    N30 X-4. Y-0.0225 F#9
    N40 X-3.25
    N50 G3 X-3.25 Y0.0225 I0 J0.0225
    N60 G1 X-3.9
    N70 G0 Z1.
    N80 X-4.05 Y-.01
    N90 M11
    N100 M99
    O2355 (FINISH)
    N10 M10
    N30 X-4. Y-.0325 F#9
    N40 X-3.25
    N50 G3 X-3.25 Y0.0325 I0 J0.0325
    N60 G1 X-3.9
    N70 G0 Z1.
    N80 X-4.05 Y-.01
    N90 M11
    N100 M99
    O2356 (Mill .380 slots)
    N10 M10
    N20 G0 X-4.1 Y0.
    N30 Z3.
    N40 G1 Z2.512 F100.
    N50 X-3.6 F#9
    N60 Z3.0 F100.
    N70 X-4.1 Y0.
    N80 Z2.507
    N90 G41 D3 X-4.025 Y-0.034 F#9 (DIA. OFFSET)
    N100 X-4. Y-.034
    N110 X-3.6
    N120 G3 X-3.6 Y0.034 I0. J0.034
    N130 G1 X-4.05
    N140 G0 Z4.
    N150 G40 X-4.1 Y0.
    N160 M11
    N170 M99
    O2357 (8 - SLOTS)
    N10 C0.
    N20 C45.
    N30 C90.
    N40 C135.
    N50 C180.
    N60 C225.
    N70 C270.
    N80 C315.
    N90 M99
    N10 M10
    N20 G0 X-11. Y0.
    N30 Z3.
    N40 G1 Z1.525 F100.
    N50 X-10.5495 F#9
    N60 Z2.0 F100.
    N70 X-11. Y0.
    N80 Z1.520
    N110 X-10.5495
    N130 G1 X-10.92
    N140 G0 Z4.
    N150 G40 X-11. Y0.
    N160 M11
    N170 M99
    O2359 (4 - .255 SLOTS)
    N10 C0.
    N20 C90.
    N30 C180.
    N40 C270.
    N50 M99
    O2360 (Mill .1625 SLOTS)
    N10 M10
    N20 G0 X-12. Y0.
    N30 Z2.0
    N40 G1 Z1.28 F100.
    N50 X-11.687 F#9
    N60 Z3.0 F100.
    N70 X-12. Y0.
    N80 Z1.28
    N90 G41 D5 X-11.95 Y-.0109 F#9 (DIA. OFFSET)
    N100 G1 X-11.92 Y-.0109
    N110 X-11.6773
    N120 Y.0109
    N130 X-11.9
    N140 G0 Z3.
    N150 G40 X-12. Y0.
    N160 M11
    N170 M99
    O2361 (Mill .1625 SLOTS)
    N10 M10
    N20 G0 X-12. Y-.14
    N30 Z2.0
    N40 G1 Z1.28 F100.
    N50 G41 D6 X-11.9 Y-0.1188 (DIA. OFFSET)
    N60 X-11.8358 Y-.1188 F#9
    N70 X-11.7673 Y-.0502
    N80 X-11.642
    N90 G3 X-11.638 Y-0.0462 I0. J0.004
    N100 G1 Y0.0462
    N110 G3 X-11.642 Y0.0502 I-0.004 J0.
    N120 G1 X-11.7673
    N130 X-11.8358 Y.1188
    N140 G0 Z3.
    N150 G40 X-12. Y0.
    N160 M11
    N170 M99
    O2362 (8 - HOLES)
    N10 C45.
    N20 C90.
    N30 C135.
    N40 C180.
    N50 C225.
    N60 C270.
    N70 C315.
    N80 M99
    O2363 (Mill .685 HOLES)
    N10 M10
    N20 G0 G90 Z1.
    N30 G1 Z.1 F100
    N40 Z-.45 F#9
    N50 G1 G91 X.08
    N60 G3 X0. Y0. I-.08 J0.
    N70 G1 X.07
    N80 G3 X0. Y0. I-.15 J0.
    N90 G1 X-.15
    N100 G0 G90 Z1.
    N110 M11
    N120 M99
    O2364 (Mill .705 HOLES)
    N10 M10
    N20 G0 G90 Z1.
    N30 G1 Z.1 F100
    N40 Z-.45 F#9
    N50 G1 G91 X.16 Y0.
    N60 G3 X0. Y0. I-.16 J0.
    N70 G1 X.005
    N80 G3 X0. Y0. I-.165 J0.
    N90 G3 X0. Y0. I-.165 J0.
    N100 G1 X-.165
    N110 G0 G90 Z1.
    N120 M11
    N130 M99
    Registered beege's Avatar
    Feb 2008
    The F and A variables assign a value to variable #9 and # 1, respectively. F is the 9th letter in the alphabet, and A is the first. When you have a value passed through on the G65 line, it can be used for ANYTHING in the sub-programs, like X#9 or G#9. In your case F is used to pass a value for feedrate (F#9) and A is used to pass a value for another feedrate (F#1).
    Feb 2006
    india
    And when a macro calls another macro (which is called a nested macro), a new set of local variables (#1, #2 etc) are used for the nested macro.
    Jun 2008
    Quote Originally Posted by camtd View Post
    O2353 (ROUGH)
    N10 M10
    N20 G0 X-3.768 Y0
    N30 G1 Z0.48 F200.
    N40 Z0.225 F#9
    N50 Z0.48 F200.
    N60 X-3.653 Y0
    N70 Z0.225 F#9
    Beege and Sinha hit it on the head. The first line of your program N190 calls program 2353 and when it calls that program #9 is set to 1.5 (F1.5) and #1 is set to 2.9 (A2.9). Now in the program at line N40 your feedrate says F#9, well #9 is set to 1.5 so when the program reads this line it will read F#9 as F1.5
    The main reason this is usefull is because if you wanted to change the feed from 1.5 to say 3.5 you only have to change the F1.5 in line N190 instead of having to change it at every feed call in the program.
    Stevo
    Nov 2005
    I think I get it.
    So if in the main program I put B5.0 then when I go to my subprogram and put
    F#2 that will give my feedrate 5.0
    If that is correct? I think I get that part now.
    Can anyone recommend a verifier to view and help create parametric code?
    I have found this one but did not get a price yet
    NCManager.download
    Thank You helping past this sticking point.
    Feb 2006
    india
    Since I am a teacher, I always emphasize use of correct terms.
    A "subprogram" is not same as a "macro."
    A macro is called by G65 (plus some other methods), and data can be passed on for use inside it.
    A subprogram is called by M98 (plus some other methods), and data cannot be passed on.
    A macro has its own set of local variables.
    A subprogram uses the variables of the calling program.
    Naturally, I would deduct a few marks for this statement (even though what you have in your mind is absolutely correct):
    "So if in the main program I put B5.0 then when I go to my subprogram and put
    F#2 that will give my feedrate 5.0"
    You have to accept me as I am. Some "stupid" teachers are like me only.
    Jun 2008
    Bingo. Absolutely right!!
    Quote Originally Posted by sinha_nsit View Post
    Sinha….I accept you as you are . I actually learn quite a lot from you. I have always been more hands on along with picking things up quickly and retaining it. However I never retained the proper verbiage of things. So I usually sound like an idiot when talking about a topic to say a “teacher” but I always knew what I was talking about (if that makes any sense). Basically I could never tell you why we had to do something a particular way but I knew that we had to.
    Stevo
    1. Variables
      By kz1000 in forum Mach Wizards, Macros, & Addons
      Last Post: 12-17-2009, 06:04 PM
    2. Need Help!- Short on Variables
      By hydrospin01 in forum Fanuc
      Last Post: 02-14-2008, 08:03 AM
    3. Variables 500 to 531
      By viorel26 in forum Fanuc
      Last Post: 09-30-2007, 03:30 AM
    4. System variables
      By jorgehrr in forum G-Code Programing
      Last Post: 02-18-2007, 08:26 PM
    5. Variables/Macro uses....
      By theemudracer in forum Fanuc
      Last Post: 12-13-2006, 02:45 PM
