Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 10-13-2010, 04:38 PM
gtrrpa is on a distinguished road
Parametric Looping problem
I'm counterboring a .843 dia hole at .490 deep "rough".There is always a hole in these parts that very. In this case the thru hole is .283.The depth finishes at .500 and is constant. So I need a variable that I can change for the thru hole which can be changed and I need to LOOP the last .01 at .002 each pass to create a very sharp edge at the intersection of the bore and the bottom of the .5 face.The boring bar needs to cut up from the inside of the bore to the .843 dia..I've created this loop b4 but for some stupid reason I'm knockin my head against the walls...............Help would be appreciated.....Thx....
Old 10-13-2010, 10:21 PM
houstonsamuel is on a distinguished road
Is this a fanuc controlled machine?
Old 10-14-2010, 05:52 PM
Yes fanuc 21i On a hardinge conquest gt
Old 10-14-2010, 07:49 PM
you can use #500 or what ever variable is free for your through hole diameter. you can set the variable in the controller or set the variable in the program(#500=.25.
G0 X#500;
G0 Z____;
G1 X.843;
for the loop you can do this many different ways. I hope this jogs you brain.
(FINISH CYCLE)
#510=-.490(Z START)
#511=.010(FINISH DEPTH)
#512=.002(DEPTH OF CUT)
#513=[#511/#512](MATH FOR # OF PASSES)
#514=0
WHILE[#514LT#513]DO1
#514=[#514+1]
G0X#500
G0Z-[.490+[#514*#512]]
G1X.483
G1Z-.490
END1
G0X#500
G0Z.1
I WORTE THIS ON THE FLY SO THERE MAY BE A MISTAKE PLEASE DOUBLE CHECK ME.
I hope this helps
Old 10-20-2010, 01:09 AM
sinha_nsit is on a distinguished road
For a simple application such as this, you can even use G94 five times (in this case).
You would need to vary only start X for G94, to suit different initial bores, for which you can use a variable.
The posted macro looks ok, but would not work when the number of passes comes out to be a fractional value (not in this case, of course). And, read G1X.483 as G1X.843.
Old 10-20-2010, 07:26 AM
I knew I messed up somewhere. I guess I have never used a G94 before. Is G94 a face turning cycle?
Old 10-20-2010, 07:50 AM
Yes.
It has some similarity with G90 cycle.
G90 is used for diameter turning / taper turning.
G94 is used for facing / taper facing.
This is for G-code system A.
Old 10-21-2010, 02:41 PM
looping macro
Haven't worked much on looping macro but going to today. I've got it to loop but keep getting an error when it goes to retract. Any help?
Old 10-21-2010, 06:22 PM
Didn't quite understand that last post. Are you using the macro or the g94?
Old 10-22-2010, 12:28 AM
You can even use G94 inside a macro.
My advice is, first try to master the canned cycles. In many cases, these would serve the purpose, and the program would be simple. Macro programming should be the next step.
  #11   Ban this user!
Old 10-22-2010, 08:56 PM
stevo1 is on a distinguished road
Can you tell us the alarm number and possible post the code in which you are getting the alarm??
Stevo
  #12   Ban this user!
Old 11-01-2010, 03:08 PM
Looping program
Sorry guys,My 1st statement was wrong. I'm not using a Macro (G65) I'm trying to use a looping program like houstonsamuel wrote. Sorry, I'm still having problems with having it retract? Hmmmmm I'll send you alarm and program...Thanks all
Looping command? rigo430 Haas Lathes 1 04-11-2010 05:35 PM
Using an IF statement inside a While looping ggborgen Parametric Programing 6 06-23-2009 12:40 PM
LOOPING? with Camsoft?? nelZ CamSoft Products 15 10-15-2008 03:56 PM
Program Looping Bohemund CamSoft Products 7 05-26-2007 11:08 AM
Sub Looping murphyspost Daewoo/Doosan 8 12-27-2006 10:28 AM
