Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 10-11-2010, 08:13 AM
ggborgen is on a distinguished road
#50467=#50467OR-65536
Gentlemen,
I saw this macro statement in a renishaw probing macro #9733 for a mazak with a 640m fusion control and I was wondering if someone out there can explain this statement to me? Here are other statements that are like it in this macro:
#50467=#50467OR32
#50467=#50467OR64
#50467=#50467OR128
#50467=#50467OR512
#50467=#50467OR256
#50467=#50467OR1024
#50499=#50499OR1
And what are system variables #50467 and #50499?
Thank You
Old 10-12-2010, 05:57 AM
guypb is on a distinguished road
What you are looking at is part of the code used to update Mazatrol WPC values from ISO code.
If you are using ISO probing macros you may wish to use the measured deviation of a feature to update the Active Mazatrol WPC rather than ISO WPCs (G54 etc...)
I've recently been doing this on a couple of Mazaks and it works well - I have found one Mazak where it doesn't work.
Even though the code is incorporated into the Renishaw macros - it's originally published by Mazak.
PM me if you want some more info - I (sadly) have a video of the code in action.
Old 10-12-2010, 07:29 AM
Is this in binary?Something like Bit anding?
Old 10-13-2010, 10:37 PM
ProProcess is on a distinguished road
"OR" is a bitwise operation seen here
It basically combines the value of the two binary statement into one binary statement without loosing any of the active [value 1] bits.
Control the process, not the product!
Machining is more science than art, master the science and the artistry will be evident.
