Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 09-21-2010, 01:45 PM
roger_e is on a distinguished road
paramteric programming for a fresnel lens
We have the formulas to get output from a fresnel integral....we can even get that data on a spread sheet.
How to write a program to take the data..better yet the formula inputs and turn it into G-Code
Old 09-22-2010, 03:11 AM
andy55 is on a distinguished road
will you be making the lens on a lathe or on a mill?
what material?
does your output geometry look something like this?
http://en.wikipedia.org/wiki/File:Fresnel_lens.svg
Old 09-22-2010, 06:06 AM
mmmilligan is on a distinguished road
Lens Manufacture
I recall producing an Application for a UK client, a good few years back, which
did exactly this.
Basically the method was :-
CAD Module
Using VB script a macro was produced which produced the Curve based
the equation and some other Parameters such as Included Angle+radius.
The VB script would then calculate a series of points which lie on the
curve.
The VB script would then submit these points to the CAD Curve Fitting
routine which would produce a Tangential (Convex or Concave) curve
which then be passed to the CAM Turning module.
CAM Turning Module
The CAM turning module would then be used to produce a toolpath.
This was a few years ago and since then the CAD module has aquired a Template system which could be employed and the CAD + CAM modules are available as Servers using microsoft auto technology.
These new features make it possible to develope a fully automated Bespoke
application which take the initial parameters and produce a dimensioned
drawing and G code file witht he Dolphin modules being used as background servers invisible to the user.
michael
Dolphin CAD CAM systems Ltd
Dolphin CAD CAM Ltd
Old 10-01-2010, 05:04 AM
norbert.barnard is on a distinguished road
if you can make the calculations in a xls spreadsheet, then you can also recreate these formula's in macro B (i can only speak about fanuc cnc's), no special software requiered.
the calculation will save the point data in a sequential variable range, start & end number decided by you.
then write a normal cnc part program that will call this variable-range in sequence to produce the shape calculated.
the variable range is called by using a loop that index the variable number, making the program very short.
Old 10-01-2010, 07:21 AM
sinha_nsit is on a distinguished road
Post the drawing and formulae for specific suggestions.
Paramteric Program Ashish B Parametric Programing 53 02-25-2011 12:44 AM
Turning fresnel formula output into g-code roger_e Environmental & Alternate Energy 2 09-24-2010 03:39 AM
Need Help!- Focusing lens cmh6473 Laser Engraving & Cutting Machines 5 10-28-2009 03:57 AM
DUAL FOCUS LENS (bifocal lens) bibi Laser Engraving & Cutting Machines 5 03-17-2009 05:03 PM
Where to buy lens? medved Mechanical Calculations/Engineering Design 5 12-30-2005 02:49 AM
