Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 05-28-2010, 09:29 AM
Dam Dam is offline
Dam is on a distinguished road
Passing profile to a macro
Hello,
I'm a mechanical engineer, and I'm developing a set of macros to ease the work of similar parts on our lathes.
What I need now is to use the G71 built in macro inside a custom macro.
The use of G71 is clear to me: in the second line of the G71 calling I have to put e.g. P100 Q200 (together with some other parameters) to tell the control that my profile is defined between lines N100 and N200.
But how can I put the G71 command inside a CUSTOM MACRO having the profile defined in the MAIN PROGRAM?
In other words, how can I realize something similar to what Fanuc programmed, when it created a macro (G71) that uses a block (of profile definition) in the main program?
I need this for a lot of reasons that I can't explain now.
Any idea?
Old 05-28-2010, 09:31 AM
Dam Dam is offline
PS: I work on fanuc 0i, 18 and 21
Old 05-28-2010, 11:02 AM
stevo1 is on a distinguished road
What you can do is define the shape using variables in your main program and then use the subprogram to machine the part with G71.
O0001(main program)
#100=10.(od diameter)
#101=1.(z distance to cut)
#102=.01(finish stock on x)
#103=.05(pick size)
#104=.01(feed)
#105=200(speed)
M98P2
M30
O0002(sub program)
G0X11.Z1.
Z.1
G96S#200M3
G71P100Q200U#102W0D#103F#104
N100G0X#100
Z-#101
N200X#101+.1
G0Z1.
M99
I just slapped this together as a reference so I am sure that there are some errors in it but it gives you the general idea.
Just as a side note I don’t like canned cycles. They usually have a lot of wasted time in them. If you are going to go this far I would just write a macro designed to do what you need instead of putting a canned cycle in it. But there is nothing wrong with doing it as above.
Stevo
Tags
g71, macro, profile
Passing Geometry back and forth between Cad and Cam Mike RZMachine Dolphin CADCAM 4 10-13-2009 08:31 AM
Need Help!- Macro A or Macro B On fanuc o-md macrosat Fanuc 1 07-29-2009 06:49 AM
Testing program for Macro (Fanuc Macro B) NickDP Fanuc 2 03-27-2009 03:15 PM
Convert Fanuc Macro to Fadal Macro bfoster59 Fadal 1 11-08-2007 11:41 PM
passing arguments to a sub program kiprip Mazak, Mitsubishi, Mazatrol 1 07-13-2006 11:11 AM
