Here is a quick translation of your supplied program written in HDH.
0 BEGIN PGM VAR-RAD MM
1 Q20 = 10 ;NUMBER OF TURNS
2 Q19 = 50 ;START RADIUS
3 Q8 = 40 ;END RADIUS
4 Q7 = 30 ;TOTAL DEPTH
5 Q1 = 45 ;START ANGLE X AXIS
6 Q17 = 1 ;INCREMENT IN ANGLE
7 Q9 = 60 ;FEEDRATE
8 ;
9 FN 12: IF +Q19 LT +0 GOTO LBL "ERROR" ; (NEGATIVE START RADIUS)
10 FN 12: IF +Q8 LT +0 GOTO LBL "ERROR" ; (NEGATIVE END RADIUS)
11 FN 12: IF +Q20 LT +0 GOTO LBL "ERROR" ; (NEGATIVE NUMBER OF TURNS)
12 ;
13 FN 18: SYSREAD Q50 = ID270 NR1 IDX1 ; (Current X-position determined)
14 FN 18: SYSREAD Q51 = ID270 NR1 IDX2 ; (Current Y-position determined)
15 FN 18: SYSREAD Q52 = ID270 NR1 IDX3 ; (Current Z-position determined.
16 Q53 = Q50 - Q19 * COS ( Q1 )
17 Q54 = Q51 - Q19 * SIN ( Q1 )
18 Q55 = Q17 ;
19 Q56 = Q55 ;
20 ;
21 LBL "BEGIN"
22 Q61 = ABS Q56
23 Q62 = 360 * Q20
24 FN 9: IF +Q61 EQU +Q62 GOTO LBL "END"
25 FN 12: IF +Q61 LT +Q62 GOTO LBL "END"
26 Q57 = Q19 ( ( Q19 - Q8 ) * ABS Q56 / ( 360 * Q20 ) )
27 Q58 = Q53 + Q57 * COS ( Q1 + Q56 )
28 Q59 = Q54 + Q57 * SIN ( Q1 + Q56 )
29 Q60 = Q52 + ( Q7 * ABS Q56 / ( 360 * Q20 ) )
30 L X+Q58 Y+Q59 Z+Q60 FQ9
31 Q56 = Q56 + Q55
32 FN 9: IF +0 EQU +0 GOTO LBL "BEGIN"
33 ;
34 LBL "ERROR"
35 ;ERROR IN PROGRAM
36 STOP
37 LBL "END"
38 END PGM VAR-RAD MM
Last edited by hansdie; 01-01-2012 at 06:05 PM. Reason: mistake with "end" q parameter
