Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 05-21-2010, 02:09 AM
Ashish B's Avatar
Ashish B is on a distinguished road
Question Setting G59 Offset through Macro Program
Hi
How to set Machine home position as offset (G59) in a program through Macro Programming.
Ash
Old 05-21-2010, 08:07 AM
ggborgen is on a distinguished road
If you mean machine home to be part zero this should work
#5321=X
#5322=Y
#5323=Z
These system variables are Fanuc.
Hope this helps
Old 05-22-2010, 03:15 AM
Ashish B's Avatar
Hi
Actually these are the variables which stores the machine position (may be absolute, home, relative )
But how to transfer these values to G59 offset.
Ash
Old 05-22-2010, 08:19 AM
christinandavid's Avatar
christinandavid is on a distinguished road
Search for posts/threads regarding the use of G10.
G10 is commonly used to load Work/Tool Offsets (or reset them).
eg G90 G10 L2 P6 X#5321 Y#5322 Z#5323
DP
Old 05-22-2010, 10:22 AM
dcoupar's Avatar
I'm not quite sure if this is what you are trying to do, but...
On a 21iM-B:
#5021 is the current machine position in X
#5022 is the current machine position in Y
#5321 is the X value for G59
#5322 is the Y value for G59
G91 G28 X0 Y0 (MOVE X AND Y TO HOME)
#5321 = #5021 (SET G59 X TO CURR MACH POS)
#5322 = #5022 (SET G59 Y TO CURR MACH POS)
Old 05-22-2010, 10:08 PM
Ashish B's Avatar
Hi
In the procedure mentioned, we need to go to call a home position return command first & than use
#5321=#5021
But is there any other way to directly set the Work offset as Home Position.
I think this may work -
#5321=0.0
#5322=0.0
G90 G59 X-15.0 Y-15.0
This will directly locate the spindle on a position offset by 15 mm from the machine home position.
Your comments/suggestion please.
Ash
Old 05-23-2010, 07:49 AM
dcoupar's Avatar
Why not just use G53 instead of G59?
Old 05-23-2010, 08:09 AM
Ashish B's Avatar
What G53 ?
Old 05-23-2010, 09:43 AM
dcoupar's Avatar
Most Fanuc controls use G53 as a one-shot Machine Coordinate System.
G53 G90 X-15. Y-15. positions X and Y -15. from Machine Zero.
Old 05-23-2010, 10:15 PM
Ashish B's Avatar
Ok...
If i say G53 G90 G0 X-10.0 Y-10.0
it will move directly to desired position (without going to home position)
AM I RIGHT ?
  #11   Ban this user!
Old 05-23-2010, 10:48 PM
dcoupar's Avatar
Yes
  #12   Ban this user!
Old 05-24-2010, 12:00 AM
Ashish B's Avatar
So, after G53 If i command G54 it will follow the G54 coordinate system...aM i Right ?
Is there any fuss to restore the Zero Position just like G92 which is a temporary shift command ?
Is G53 preset as machine zero by the controller or we need to define it.
setting work offset(G54 etc) dek Machinist Feedback 1 04-06-2010 09:17 PM
How setting tools and setting offset John246 Sharp CNC 9 03-17-2010 09:31 PM
Testing program for Macro (Fanuc Macro B) NickDP Fanuc 2 03-27-2009 03:15 PM
Need help on setting up a macro mgb1974 G-Code Programing 11 04-17-2008 09:31 AM
macro program for work offset cncwhiz Fanuc 4 12-14-2007 06:28 AM
