Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing
Parametric Programing (custom macro b, fadal macro, okuma user task)
Old 02-25-2010, 11:12 PM
dpuch is on a distinguished road
Ball in a cage example
I was feeling like making something fun, and this looked like it.
I stole the original code from EMC's wiki but then modified it slightly to run on fanuc controls, and added roughing passes. I only had a stub ball mill, so the roughing lets you specify a max cutter engagement depth for each pass. There are lots more ways to clean it up an add more features.
Code:
O0070  (BALL IN CUBE)
(CENTER TOP OF CUBE IS XYZ ZERO)
#1=1.5 (SIZE OF BOX AND DIAMETER OF FINISHED BALL)
#2=0.0625 (BALL MILL CUTTER RADIUS)
#3=0.125 (SIZE OF BOX BARS)
#4=5.0 (DEGREES OF STEPOVER RESOLUSION AT THE CORNERS)
#5=#4 (STEPOVER COUNTER)
#6=[[#1/2]+#2] (ACTUAL CUTTER PATH RADIUS OF SPHERE -- CUTTER RADIUS + RADIUS)
(#6 ALSO MINIMUM TOOL FLUTES REQUIRED FOR FULL SPHERE)
#7=5.0 (FEED RATE)
#10=2.0 ( > 1 EQUALS A ROUGH PASS AT #10*#4 STEPOVER)
IF [#10 LT 1.0] THEN #10=1.0 (SAFTEY CHECK - KEEP #10 >= 1.0)
#11=0.05 (ROUGH PASS MATERIAL TO LEAVE IN Z)
#12=0.17 (MAX Z DEPTH PER ROUGH PASS)
#13=FUP[[#6-#11]/#12] (ROUGH PASSES TO TAKE)
#14=[#6-#11]/#13 (Z PER ROUGH PASS)
#15=#11+#14*#13 (SET ROUGHPASS Z OFFSET)
G90 G57 G0 X0 Y0 M3 S4000
(G43 Z1.0 H1)
Z0.1
N0010
   IF [#10 LE 1.0] THEN #15=0 (FINISH Z LEVEL)
   #8 = [[SIN[#5*#10]*#6]*SIN[45]] ( X AND Y ARC START POSISION)
   #9 = [0-[[1-COS[#5*#10]]*#6]]+#15 (ARC Z START HIGHT)
   IF [#8 LT [#1/2-#2-#3]] GOTO 20
   #8 = [#1/2-#2-#3]  (SET LAST PASS AT FINISHED BAR SIZE)
   #9 = 0-[#6 - SQRT[#6*#6 - [#8*#8+#8*#8]]]+#15
   N0020
   IF [#9 GT 0] GOTO 15 (WOULD ONLY CUT AIR, STILL ABOVE Z0)
   G1X[#8]Y[#8] F#7
   Z[#9] F[#7/3]
   G18 G02 X[0-#8]Z[#9]I[0-#8]K[0-[#9+[#6]]] F[#7]
   G19 G03 Y[0-#8]Z[#9]J[0-#8]K[0-[#9+[#6]]]
   G18 G03 X[#8]Z[#9]I[#8]K[0-[#9+[#6]]]
   G19 G02 Y[#8]Z[#9]J[#8]K[0-[#9+[#6]]]
   N0015
   #5=[#5+#4]
IF [#8 LT [#1/2-#2-#3]] GOTO 10
#5=#4 (RESET STEPOVER COUNTER FOR NEXT ROUGH-FINISH PASS)
G0 Z0.1
X0 Y0
IF [#10 LE 1.0] GOTO 9000 (DONE)
#13=#13-1.0 (STEP DOWN Z RIOUGHING PASS)
IF [#13 LT 0] GOTO 100 (ROUGHING DONE)
#15=#11+#14*#13 (STARTING ROUGHPASS Z OFFSET)
GOTO 10
N0100
#10=1.0
GOTO 10
N9000
G0 Z1.0
M9
M5
M30
I made the mistake of trying to cut the 6th side while just grabbing the sides of the ball :/ It is cut free at least, just not a full sphere.
Old 02-25-2010, 11:50 PM
CNCRim's Avatar
nice work!!!!!!!
Old 02-26-2010, 02:08 AM
sinha_nsit is on a distinguished road
The cube appears to have been machined from five sides, after suitably tilting it everytime. How did you ensure accuracy in positioning, so that the workpiece zero point does not shift. The starting cube may not have been a perfect cube.
I also have machined a half-sphere, but used a CAM software to generate the toolpath.
Old 02-26-2010, 02:34 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
This is one of the best things about being a machinist. We can make what ever we can imagine.
Great job on this dpuch!!!!!
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 02-26-2010, 05:35 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
Oh, I am sooo gonna make one of them. That is awesome!
I love deadlines- I like the whooshing sound they make as they fly by.
Old 02-26-2010, 07:30 AM
cyclestart is on a distinguished road
How would you approach the 6th side if cutting another one ?
Very cool btw
Anyone who says "It only goes together one way" has no imagination.
Old 02-26-2010, 08:05 AM
Andre' B is on a distinguished road
Very cool btw
There are some metal alloys available from MSC, Travers, etc. which melt at low temps, less then boiling water. And when the freeze they expand a very little bit.
So freeze the part in some of that, machine it, then melt it to get the parts.
Old 02-26-2010, 08:24 AM
samco is on a distinguished road
That is just awesome. I wrote that program initally to test the owords in emc2. I never acutally finished one to see if it actually worked.
Nice work!
sam
ID:	100825   Click image for larger version
Old 02-26-2010, 08:42 AM
re: holding for the last cut..
I was always going to machine a negative of the ball and cage and put it in a vise. The negative would hold the ball and cage well enough to finish the last side. (that was my hope anyways)
sam
Old 02-26-2010, 09:00 AM
ImanCarrot's Avatar
I've seen stuff like this b4 (but it was a lose cube) and they used wax to hold the last face.
  #11   Ban this user!
Old 02-27-2010, 03:28 PM
Thanks everyone for the comments.
Nothing special, I did start out with a cube I machined to about ±0.002" within square. I just used a fixed stop in a vice to relocate the block as I rotated it. As this was a first try I didn't really worry about trying to get really tight tolerances or fine finish.
How would you approach the 6th side if cutting another one?
Anders comment below is exactly what I was thinking of. The way the program is written you can have VERY small squares of material left on the 6 sides of the ball. I had a minor hope that clamping tight enough on these (flexing in the cage) and reducing the feed rate to about 10% would be enough. But the ball rotates too easily on such small contact points. I think it might work if it a clamp was put on 90° to keep it from rotating.
Yep, CeroBEND or CeroSAFE or similar.
Great to have your input! Yep the math and code worked well. Like I said, I did have to change the o code loop logic to fanuc IF GOTO but otherwise the original ran fine as well. Most of the other changes were just to add the roughing passes capability. Oh, and one other to make sure the last pass left the right bar size regardless of the step over.
If I get a chance to run another soon I'll take some more pictures of it in progress.
  #12   Ban this user!
Old 02-27-2010, 07:41 PM
Trevtech is on a distinguished road
Great job --- Nice
Need Help!- KM3P Card Cage wires winds1sj HURCO 1 07-05-2011 08:48 PM
Need help: Identify ball screw/ ball nut RickOmatic General Metal Working Machines 0 04-12-2009 01:02 PM
Need Help!- Programming a Ball stuby G-Code Programing 1 05-05-2008 03:11 PM
Ball Screws jessslp05 Linear and Rotary Motion 6 04-27-2008 11:28 AM
Big Ball Screw & Ball Nut mistake. Jack F General Metal Working Machines 12 04-28-2006 10:53 PM
