Need Help! Tombstone milling macro needed
Results 1 to 2 of 2
Thread: Tombstone milling macro needed
    May 2015
    Question Tombstone milling macro needed
    I am in need of a face milling macro to true up the tombstone in my HMC. It is a fairly old Kitamura Hx 400 and the B axis had went bad. And to correct it the tombstone had been milled to compensate. We just got done fixing the issue with the B axis so now the tombstone look like the top was just twisted and pulled up.
    Ideally i would want start at lower corner move over in X, retract Z, go back to Original X, increment up in Y, back in Z at depth and so on. Only macros i have been able to find start at center and incrementally go out from center.
    May 2015
    Default Re: Tombstone milling macro needed
    I found out that my Kitty has built in milling cycles they just needed to be turned on. They just run completely in background like G83 Canned cycles and the like.
