G90 and G91, no difference
Results 1 to 4 of 4
Thread: G90 and G91, no difference
    Jan 2015
    Default G90 and G91, no difference
    Hi
    I have a Midwell with FANUC O-M controller.
    In MDI-mode I run:
    G90 G00 X10 Y10
    Instead of moving absolute it's moving incremental, there is no difference if I run with G91.
    Which parameters can affect this?
    Thanks!
    Member BlueChip's Avatar
    Jun 2003
    Massachusetts
    Default Re: G90 and G91, no difference
    Have you tried putting the G90 or G91 on a line by itself? ... like this :
    G90
    G00 X10.00 Y10.0
    G91
    G00 X10.00 Y10.00
    ... I have seen this resolve the issue many times.
    Chec out our Real World Machine Shop Software at Kentech Inc. - Real World Machine Shop and CNC Software
    Including Conversational CNC Programming Software for Milling & Turning
    Jan 2015
    Yes. That gives the same result.
    Member dcoupar's Avatar
    Mar 2003
    Quote Originally Posted by itbonde View Post
    Hi
    In MDI-mode I run:
    G90 G00 X10 Y10
    Thanks!
    This is from the MDI Operation section of the 0M-C/D manual.
     In MDI operation, the setting (absolute) determines whether the
    commands are absolute or incremental. The G code (G90/G91) is
    ignored.
    So, go to the Settings screen and set Absolute to 0 or 1 depending on which mode you want.
