Pantograph for inlay work
Results 1 to 3 of 3
Thread: Pantograph for inlay work
    Registered difalkner's Avatar
    Nov 2014
    Default Pantograph for inlay work
    Just now saw this sub topic and thought I would chime in with the pantograph I just built -
    A few weeks ago I finished the pantograph I designed for doing inlay work on guitars. This was initially for use with my Dremel and flex cable. I did one simple test with it and that worked fine but I’ll do some more before I cut into some nice exotic wood or Abalone. Since I built and posted the video I have modified the pantograph to mount my Dremel directly because I discovered the flex cable chuck runout was too great to do accurate work. Also, I have added a micro-adjustment to the stylus since the video.
    It’s very smooth and precise so I’m pleased with that part of it. It will do 2:1, 3:1, and 4:1 reductions.
    My target testing piece is in the upper right hand corner of the video -
    Pantograph for inlay work-dif-inlay-pantograph-1-jpg
    Pantograph for inlay work-dif-inlay-pantograph-4-jpg
    Pantograph for inlay work-dif-inlay-pantograph-5-jpg
    Micro adjustment stylus -
    Pantograph for inlay work-micro-adjusting-stylus-jpg
    David
    Romans 3:23
    Gold Member
    Dec 2007
    Default Re: Pantograph for inlay work
    Very nice construction! Looks great!
    I used to do a lot of ad-hoc small signs years back and used an old Vermont American pantograph, but yours looks vastly superior.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Nov 2014
    Quote Originally Posted by aarggh View Post
    cheers, Ian
    Thanks, Ian! That's quite a compliment!
    David
    David
    Romans 3:23
