Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > OpenSource Software
OpenSource Software For the Discussion of Opensource CAD/CAM and NC shareware software etc)
Old 10-06-2009, 11:58 PM
jmoorm2 is on a distinguished road
Cross-section image output
I was wondering if by some means it's possible to take a 3D model and obtain a set of 2D image files (.bmp, .jpeg) of cross-sections of a given thickness that would be ready for viewing or printing on paper.
I know Photoshop CS3/4 can view cross sections of certain 3D model files and save as images easily enough, but I can imagine this to be considerably labor intensive; something automatic would be desirable.
I heard from a friend that certain 3D modeling software (like ProE) is able to output a file type consisting of a stack of cross-sections to be used by a rapid prototyper, but I have no idea if something like that could be used toward my end goal.
Any help, suggestions, or redirection would be appreciated - thanks for your time!
Old 10-07-2009, 12:49 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Vectric Cut3D will let you slice a 3D model, & output g-code. Is that what your after?
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 10-07-2009, 01:43 AM
Thanks for the reply Switcher
I know it may seem odd, but I'm actually not looking to output to a machine via code--at least not initially. I'm really looking for straight up image files :P As if I were to print them out and assemble a model by cutting them out and stacking them.
Elsewhere on the forums, someone said that Vega DATA-View can go from *.plt to g-code. Can it go backwards?--(g-code to *.plt) Then maybe I could get it in something like CorelDraw and get an image out.
Maybe there's software to go from a 3D model to a set of plotter/laser cutter *.plt's directly? That might be useful.
Old 10-23-2009, 11:52 AM
safecnc is on a distinguished road
It took me some time before realizing that the message was sent on 7 of October an not on 10 of July. Here in Italy dates are different... anyway I hope it's not too late for a suggestion.
http://www.freesteel.co.uk/wpblog/slicer/
If I understood what you are looking for.. slice.exe will do the job.
All the best
Sandro
Old 10-26-2009, 09:06 PM
Perfect! Thank you greatly, safecnc - much appreciated!
Old 10-29-2009, 12:32 AM
Dan Falck is on a distinguished road
http://code.google.com/p/wxblackcat/
lathe cross section camtd Mastercam 5 01-31-2008 09:43 AM
Machining a thin cross section XYZ machine General Metalwork Discussion 1 12-31-2007 11:54 AM
cross slide nantz Benchtop Machines 0 07-12-2006 07:09 PM
Image embossing & G-Code output example dcarr Virtual Sculptor VS3D / VScad3 Software 4 07-31-2004 08:51 PM
test image upload(CNC cross slide conversion) Rocketman Test Forum 5 03-03-2003 04:58 PM
