| OpenSource Software For the Discussion of Opensource CAD/CAM and NC shareware software etc) |
#181
Problem solved, but it took two programs at the cost of about $100. First I had to get a newer version of CorelDRAW to import my DXF file into. Secondly I bought a Corel add-on called "Artwork Optimizier for CorelDRAW Standard Edition" Corel now Exports sorted DXF files that cuts down the traverse time of the cutting tool substantially. Rolf |
#182
| Rolf, Good to hear! |
#184
HIII i am working with vb6 & drawing the semi circle with Circle command in vb6 on picturebox which is drawn fine My problem is that the endpoints are coincided with the points where i have made selection & given command to draw a semi circle So how can i coincide the points Second problem is when i m saving the semi circle in dxf format & when view in it it is shown as a polygon with 10 points connected with line Similarly when i zoom in the endpoints are not connected with the start ^& end point of line which is selected how can i overcome the problem Pls any body help is appreciated |
#185
| [ It could be a default setting of autocad that defines the graphic circle tolerance. QUOTE=bhavik;989877]HIII i am working with vb6 & drawing the semi circle with Circle command in vb6 on picturebox which is drawn fine My problem is that the endpoints are coincided with the points where i have made selection & given command to draw a semi circle So how can i coincide the points Second problem is when i m saving the semi circle in dxf format & when view in it it is shown as a polygon with 10 points connected with line Similarly when i zoom in the endpoints are not connected with the start ^& end point of line which is selected how can i overcome the problem Pls any body help is appreciated[/QUOTE] |
#186
HIIIIII I have thew problem in setting the lineStyle i.e DAshed & continous I m using VB6 & opening the DXF file & saving in DXF format But I m unble to set LSTYLE to Dashed & Again reset to Continus or solid lines Since i have toi distinguish my object with diffent lines But i m unable to do so since the LSTYLE is set in header section I want it to be change in when & were required 3 How can i do this Pls help is appriciated Another case is of displaying Filled circle How can i stored information tat thecircle is fiiled with suppose Yellow color Can this be possible Pls help |
#188
| Just rename the file to TXT extension. |
#189
Hello Mister Hill, I search for the same application but with only the G1 deplacement, it is posssible ?? thank you very much for your answer. Mat |
#190
| Hello Mat, I sell a newer version on my web site. See my Sig link below. Thank you, Wayne |
#191
Web site has either been sold, hacked or something. All I see is a lady and I'm not fluent in the language presented. |
#192
| Hello Mat, Thank you for letting me know about this. My Web Host has been hacked for a third time. I am getting sick of this. Grrrrrrr.... Wayne |
| Looking for Mandolin g code or dxf | mredican | Musical Instrument Design & Construction | 73 | 11-17-2011 11:40 AM |
| parametric programming | Karl_T | CamSoft Products | 21 | 05-24-2005 02:58 PM |
| G Code to DXF | sanders50 | G-Code Programing | 2 | 02-16-2005 03:09 PM |
| DXF Catalog | CNCdude | Product Announcements & Manufacturer News | 2 | 08-26-2004 09:07 PM |
