Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > OpenSource Software
OpenSource Software For the Discussion of Opensource CAD/CAM and NC shareware software etc)
Old 07-18-2009, 03:07 PM
CLaNZeR's Avatar
CLaNZeR is on a distinguished road
Bed Level Gcode Creator V0.1 Beta
Knocked up a quick small application to create Gcode for levelling your bed.
More features to be added yet.
Please note, that the program takes it for granted that you are using the top of the material as Zero.
So when setting the depth to say 3mm you are in fact telling it to clear 3mm down from zero point (-3.0mm).
Please let me know if any bugs in the calculations. But seems okay this end.
Sorry only Metric at the moment, will add Imperial later.
Cheers
Sean.
http://www.cncdudez.co.uk
Sprocket gcode/cad file creator mgreene General CNC (Mill and Lathe) Control Software (NC) 9 08-16-2010 03:56 PM
CREATOR CJ-120 GETTING OLD? keen EDM Machines 0 06-25-2009 03:39 AM
Isnt gcode a little outdated? higher-level cnc coding guru_florida General CNC (Mill and Lathe) Control Software (NC) 21 01-10-2008 02:10 PM
Key Creator gosserwb Cadkey / KeyCreator 3 05-22-2007 09:08 AM
HPGL or PLT Creator tburkard General CAM Discussion 2 11-28-2005 04:15 PM
